Announcements
Fusion360 closes right after opening on Windows 10.
doeason
doeason
I have used Fusion 360 on the current machine an HP laptop running windows 10 for 9 months.  2 Days ago Fusion360 was open but not in current use.   However I noticed it close by itself.  Today when I try to open it the default design window opens up along with the title and command bar at the top but after about 10 seconds it closes with no additional info.
In order to fix this I have already made sure no virus software is running.  I updated my NVIDIA driver.   I tried setting the QT_OPENGL variable to software and then to angle.   But it still does not work.
mohammed.aliTDPXK
Hello @doeason ,
Can you please try the clean uninstall?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Let me know if this helps.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
doeason
Yes that did fix it. Thank You.
