@Anonymous Thank you for the logs.
The errors in the logs shows that this is a permission issue of a file already in use. Can you try a restart of your machine and then try the install?
Also, is this a machine where you previously had installed Fusion?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
tried restart still same error. Yes, it was installed on this machine. ever since the last maintenance you guys did, I was stuck working offline. that's why the uninstall and reinstall attempt. finally got it to install by renaming Autodesk folder in appdata folder.
