Hey everyone,
I purchased some CNC template files to cut out some parts. I got them in the form of DXF files that I'm 95% sure were built using Fusion 360. However, whenever I import a single DXF file, fusion just tanks and won't do anything. I looked through the help documentation with no resolution, and other times, I've seen this come up with complex sketches. However, the current ones I'm working with are simple.
I'm running with 16GB of ram, and Fusion only showed it was consuming around 3GB of it, yet it was still unresponsive. I'm stuck because I can't do anything. I even tried importing the DXF, projecting the lines to a new sketch, then breaking the link and deleting the original sketch layer from the DXF, but it still is extremely slow.
Any help would be appreciated. I've attached an example file with one of the sketches. I'm trying to lay this out in my 48" x 48" space, along with a few other parts to cut on the CNC.
