Thank you Mark
This is all very helpful. Much of your advice I have already started to pick up, but some of your suggestions are new and will be very helpful. I started using Fusion with almost no 3D modeling experience and this forum has been a great resource in my learning.
HOWEVER, my issue with drawings crashing has unfortunetly not resolved. I was fully prepared to take the blame with my poor workflow, but even with very simply models I am still finding it almost impossible to make a drawing. For example, I needed to add a component to the model i have been working with. Instead of adding it to the existing model, I started a new design. This is a very simple simple component. I inserted a screw from mcmaster which will need slight modification. The head diameter needs to be reduced which I did with a single simple sketch and an extrude to remove outer part of the screw head. Even with no other files open in fusion, I can't create a 2d drawing of this part without crashing fusion. I have tried many times and it crashes every single time.
The file is here: https://a360.co/3PVlJcF
If its helpful, I am using win11 with 16gb ram and NVIDIA Quadro Pro P620 graphics
I just did a clean re-install of the NVIDIA driver that I downloaded direct from Autodesks recommended driver resource. but this didn't make any difference. Below is the Fusion graphics diagnostics info (I don't know what most of this means, so let me know if you see any issues).
Any idea why I still can't get drawing to work without crashing. I have been using Fusion for several years with no issue until about 2 months ago. It started as an occasional issue and now it is so prevalent that I can't even get this simple job done. I have been trying to get prints to the shop for over three days now and simply can't get fusion to generate the drawings....
[GPU Information]
GPU Device: NVIDIA Quadro P620
GPU RAM: 2048 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 536.25
GPU Driver Date: 06/12/2023
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
