Fusion Support
Fusion Simulation not working - Cloud Solve service issues?
9 REPLIES 9
Message 1 of 10
grant.lumsden
401 Views, 9 Replies
Hi there,
I have not been able to run static stress analysis for the past 24 hrs. Even a very simple test cantilever gets stuck at "Solving... 1%" (I've waited over an hour so far!) Models I've successfully run previously will also not solve.
I have done the latest Fusion update from last night, but the problem is still the same...
Is it just me? Or is this a wider issue?
9 REPLIES 9
Message 2 of 10
henderh
in reply to: grant.lumsden
Hi @grant.lumsden,
We've had issues with particular accounts, and have resolved the issue on our back-end.
Could you try the following?
  1. If there are any jobs which still appear stuck, please cancel the studies
  2. 'Reset Fusion' using the Service Utility
  3. Re-submit the solves
If you're still facing issues, could you attach the log files when the job is stuck and leave the job running?
  • Help pull-down > Support and Diagnostics > Diagnostic Log Files
We apologize for the inconvenience.
Hugh Henderson
QA Engineer (Fusion Simulation)
Message 3 of 10
grant.lumsden
in reply to: henderh
Many thanks for your help!
Have reset (twice now) and logged back in.
I have reloaded the job and it has the same issue.
The job is still running, log files attached
Message 4 of 10
henderh
I've asked development to look into your stuck job. We should have more info tomorrow.
I appreciate your patience.
Hugh Henderson
Message 5 of 10
henderh
Hi @grant.lumsden,
Your account should be fixed now. Please let us know if you're still facing issues.
Hugh Henderson
Message 6 of 10
Many thanks Hugh - this is all working again 🙂
Message 7 of 10
Hello @henderh,
I seem to have the same issue. The solving of simulations stuck at 1%. The problem seems to be connected to my account and not the device, as I tested solving it from several devices with my account and the files can be solved in other accounts.
Reinstalling and Resetting the software didn't solve my problem.
I attached my log files.
Another student had the same issue but it vanished after a day.
I would appreciate it if you could help me out too.
Message 8 of 10
henderh
in reply to: mlwilhel94B4S
Hi @mlwilhel94B4S,
The wires are untangled now for your account. Please let us know if you're still having issues.
Apologies for the inconvenience.
Hugh Henderson
Message 9 of 10
jebran7CLMU
Hello @henderh,
I have the same issue. My simulations are stuck at 1% and "scheduled" for a few days now. I canceled and deleted any and all running simulations but the problem seems to be with the cloud simulation management. I even reset, deleted, and reinstalled Fusion but the problem is still not solved. I have attached my logs and would appreciate your help with this. Thank you!
also, it would be great if Fusion had a feature where all scheduled and running simulations could be managed even if the specific files with the simulation jobs are not open.
Message 10 of 10
henderh
in reply to: jebran7CLMU
Hi @jebran7CLMU,
I see eight jobs sent last week that appear to have processed successfully. Are you still seeing issues?
Best regards,
Hugh Henderson
