Fusion projects visible on some computers but not others.
steve_curtland
Message 1 of 16
steve_curtland
My students and I are having a problem.  We can see the projects folders on some computers but not others.  Here are screen captures from my account on two computers.project visible.PNGCapture (1).PNG
How can I fix this?
Replies (15)
Message 2 of 16
RajkumarIlanchelian
@steve_curtland Can you please tell us which version of Fusion you are on? We fixed similar issues in our latest 2.0.20494.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 16
steve_curtland
I believe I am using the latest version. 2.0.19440 x86_64
Message 4 of 16
RajkumarIlanchelian
@steve_curtland On the machine that you are not seeing the data panel refresh, can you please try the below from the article?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-do-a-manual...
Autodesk Fusion
Join Fusion Insider
Message 5 of 16
steve_curtland
I will try that when I get back to that computer, but I am not comfortable
having students rename files. It there a student friendly approach?
Message 6 of 16
RajkumarIlanchelian
@steve_curtland you do not have to necessarily rename. just delete that file and that should work too. It essentially brings it all back when you retreat Fusion.
Autodesk Fusion
Join Fusion Insider
Message 7 of 16
steve_curtland
That did not resolve the issue.
Message 8 of 16
RajkumarIlanchelian
@steve_curtland hmmmm. OK. ITs not refreshing the data panel on that machine. Can you please try the below that forces this?
1. Go to Fusion team - https://login.autodesk360.com/login
2. This should list all the files you have
3. Go to one of the files - select - Open in desktop
4. This should launch Fusion
Now does that help populate the data panel?
Autodesk Fusion
Join Fusion Insider
Message 9 of 16
steve_curtland
It opened the file, but did not populate the panel.
Message 10 of 16
RajkumarIlanchelian
@anurag_naik Any ideas on what else to try out here or other information needed to track this down?
Autodesk Fusion
Join Fusion Insider
Message 11 of 16
anurag_naik
Hi @steve_curtland, can you please confirm a few things related to this:
  1. Are you noticing a continuous spinning reload icon (on top-bar) on data-panel
  2. Are these projects/folders or files available via Open dialog (File -> Open)
  3. Can you please provide the Diagnostic logs from one of these machines which have an issue (Help (? icon) -> Support and Diagnostics -> Diagnostic Log Files)
  4. Also if you can share a dump of dxdiag (steps) to get the system configuration of any of the machines having this issue
Anurag Naik
Message 12 of 16
steve_curtland
System Information
Time of this report: 10/30/2024, 09:43:19
Machine name: HS10919
Machine Id: {40134DA4-76B0-44E9-B3DE-0D755D3492D3}
Operating System: Windows 10 Enterprise LTSC 64-bit (10.0, Build 19044) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Precision Tower 3420
BIOS: 2.30.0 (type: UEFI)
Processor: Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz (8 CPUs), ~3.6GHz
Memory: 16384MB RAM
Available OS Memory: 16276MB RAM
Page File: 9799MB used, 8907MB available
Windows Dir: C:\windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.4957 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 630
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_8086&DEV_5912&SUBSYS_06C71028&REV_04
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 8265 MB
Dedicated Memory: 128 MB
Shared Memory: 8137 MB
Current Mode: 1920 x 1080 (32 bit) (59Hz)
HDR Support: Not Supported
Display Topology: Extend
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.639648,0.329102), Green(0.299805,0.599609), Blue(0.149414,0.059570), White Point(0.312500,0.328125)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: EPSON PJ
Monitor Id: SECA51C
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdumdim64.dll,C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd10iumd64.dll,C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd10iumd64.dll,C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd12umd64.dll
Driver File Version: 27.20.0100.8854 (English)
Driver Version: 27.20.100.8854
DDI Version: 12
Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.7
Hardware Scheduling: Supported:False Enabled:False
Graphics Preemption: Triangle
Compute Preemption: Thread
Miracast: Not Supported by WiFi driver
Detachable GPU: No
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: DISABLE_HWSCH
Catalog Attributes: Universal:False Declarative:False
Driver Attributes: Final Retail
Driver Date/Size: 10/13/2020 5:00:00 PM, 1449864 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B78E66-1A52-11CF-0E51-A326BFC2D635}
Vendor ID: 0x8086
Device ID: 0x5912
SubSys ID: 0x06C71028
Revision ID: 0x0004
Driver Strong Name: oem23.inf:5f63e5341bf86c41:iKBLD_w10_DS:27.20.100.8854:pci\ven_8086&dev_5912&subsys_06c71028
Rank Of Driver: 00D10001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 {E07EC519-E651-4CD6-AC84-1370CCEEC851} {BCC5DB6D-A2B6-4AF0-ACE4-ADB1F787BC89} DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT {C528916C-C0AF-4645-8CB2-372B6D4ADC2A} {91CD2D6E-897B-4FA1-B0D7-51DC88010E0A} DXVA2_ModeVP8_VLD {442B942A-B4D9-4940-BC45-A882E5F919F3} {97688186-56A8-4094-B543-FC9DAAA49F4B} {1424D4DC-7CF5-4BB1-9CD7-B63717A72A6B} {C346E8A3-CBED-4D27-87CC-A70EB4DC8C27} {FFC79924-5EAF-4666-A736-06190F281443} {2364D06A-F67F-4186-AED0-62B99E1784F1} {464BDB3C-91C4-4E9B-896F-225496AC4ED6} {28566328-F041-4466-8B14-8F5831E78F8B} {6B4A94DB-54FE-4AE1-9BE4-7A7DAD004600} {8C56EB1E-2B47-466F-8D33-7DBCD63F3DF2} DXVA2_ModeHEVC_VLD_Main {75FC75F7-C589-4A07-A25B-72E03B0383B3} DXVA2_ModeHEVC_VLD_Main10 {07CFAFFB-5A2E-4B99-B62A-E4CA53B6D5AA} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {76988A52-DF13-419A-8E64-FFCF4A336CF5} {80A3A7BD-89D8-4497-A2B8-2126AF7E6EB8} {50925B7B-E931-4978-A12A-586630F095F9} {B69C20E0-2508-8790-0305-875499E0A2D0} {49761BEC-4B63-4349-A5FF-87FFDF088466}
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 1
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
PanelFitter Caps: Not Supported
PanelFitter Stretch: Not Supported
Card name: NVIDIA Quadro P1000
Manufacturer: NVIDIA
Chip type: Quadro P1000
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1CB1&SUBSYS_11BC1028&REV_A1
Display Memory: 12141 MB
Dedicated Memory: 4004 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Color Primaries: Red(0.652344,0.335938), Green(0.321289,0.610352), Blue(0.153320,0.060547), White Point(0.313477,0.329102)
Monitor Name: Dell P2417H(DisplayPort)
Monitor Model: DELL P2417H
Monitor Id: DELA0DB
Output Type: Displayport External
Driver Name: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvldumdx.dll,C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvldumdx.dll,C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvldumdx.dll,C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvldumdx.dll
Driver File Version: 32.00.0015.5612 (English)
Driver Version: 32.0.15.5612
DDI Version: 12
Hardware Scheduling: Supported:True Enabled:False
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Date/Size: 6/24/2024 5:00:00 PM, 799240 bytes
WHQL Logo'd: Yes
Device Identifier: {D7B71E3E-5FF1-11CF-7466-B3310EC2ED35}
Vendor ID: 0x10DE
Device ID: 0x1CB1
SubSys ID: 0x11BC1028
Revision ID: 0x00A1
Driver Strong Name: oem54.inf:0f066de328dd1ec8:Section008:32.0.15.5612:pci\ven_10de&dev_1cb1&subsys_11bc1028
Rank Of Driver: 00CF0001
Video Accel:
DXVA2 Modes: {86695F12-340E-4F04-9FD3-9253DD327460} DXVA2_ModeMPEG2_VLD {6F3EC719-3735-42CC-8063-65CC3CB36616} DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD {32FCFE3F-DE46-4A49-861B-AC71110649D5} DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 {1A72925F-0C2C-4F15-96FB-B17D1473603F} {15DF9B21-06C4-47F1-841E-A67C97D7F312} DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC {9947EC6F-689B-11DC-A320-0019DBBC4184} {33FCFE41-DE46-4A49-861B-AC71110649D5} DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2 {DDA19DC7-93B5-49F5-A9B3-2BDA28A2CE6E} {6AFFD11E-1D96-42B1-A215-93A31F09A53D} {914C84A3-4078-4FA9-984C-E2F262CB5C9C}
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 1
Sound Devices
Description: EPSON PJ (Intel(R) Display Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_8086&DEV_280B&SUBSYS_80860101&REV_1000
Manufacturer ID: N/A
Product ID: N/A
Type: N/A
Driver Name: IntcDAud.sys
Driver Version: 10.27.0.9 (English)
WHQL Logo'd: Yes
Date and Size: 2/24/2020 5:00:00 PM, 341360 bytes
Other Files:
Driver Provider: Intel(R) Corporation
HW Accel Level: Emulation Only
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Speakers / Headphones (Realtek Audio)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0255&SUBSYS_102806C7&REV_1000
Product ID: N/A
Type: N/A
Driver Name: RTDVHD64.sys
Driver Version: 6.0.1.6122 (English)
WHQL Logo'd: Yes
Date and Size: 6/14/2017 5:00:00 PM, 2682824 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (HD Web Camera)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name: USBAUDIO.sys
Driver Version: 10.0.19041.4355 (English)
Date and Size: 4/11/2024 5:00:00 PM, 205824 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Microphone (HoverCam Solo8+ (Audio))
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Video Capture Devices
Number of Devices: 2
FriendlyName: HD Web Camera
Category: Camera
SymbolicLink: \\?\usb#vid_05a3&pid_9331&mi_00#6&7c239da&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
Rotation: n/a
Manufacturer: Microsoft
HardwareID: USB\VID_05A3&PID_9331&REV_0105&MI_00,USB\VID_05A3&PID_9331&MI_00
DriverDesc: USB Video Device
DriverProvider: Microsoft
DriverVersion: 10.0.19041.4355
DriverDateEnglish: 6/21/2006 00:00:00
DriverDateLocalized: 6/21/2006 12:00:00 AM
Service: usbvideo
Class: Camera
DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
ContainerId: {6D764C89-DF45-57AE-93AF-A1037236EE80}
ProblemCode: No Problem
BusReportedDeviceDesc: HD Web Camera
Parent: USB\VID_05A3&PID_9331\Ucamera001
DriverProblemDesc: n/a
UpperFilters: n/a
LowerFilters: WdmCompanionFilter
Stack: \Driver\ksthunk,\Driver\usbvideo,\Driver\usbccgp
ContainerCategory: n/a
SensorGroupID: n/a
MFT0: n/a
DMFT: n/a
CustomCaptureSource: n/a
DependentStillCapture: n/a
EnablePlatformDMFT: n/a
DMFTChain: n/a
EnableDshowRedirection: n/a
FrameServerEnabled: n/a
AnalogProviders: n/a
ProfileIDs: n/a
FriendlyName: HoverCam Solo8+
Category: Camera
SymbolicLink: \\?\usb#vid_2894&pid_0029&mi_00#6&182bebea&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
Rotation: n/a
HardwareID: USB\VID_2894&PID_0029&REV_0000&MI_00,USB\VID_2894&PID_0029&MI_00
Service: usbvideo
Class: Camera
ContainerId: {A70329BE-2F54-11EF-BF82-806E6F6E6963}
BusReportedDeviceDesc: HoverCam Solo8+
Parent: USB\VID_2894&PID_0029\5&33eb7b70&0&19
UpperFilters: n/a
SensorGroupID: n/a
MFT0: n/a
DMFT: n/a
DMFTChain: n/a
ProfileIDs: n/a
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: HID-compliant consumer control device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0xFFFF, 0xBACE
FF Driver: n/a
Device Name: HID-compliant system controller
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: HoverCam Solo8+
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x2894, 0x0029
FF Driver: n/a
Device Name: Dell Universal Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x413C, 0x4503
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x8086, 0xA12F
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 6/17/2024 12:40:59, 649696 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Lower Filters: DPMDriver
| | Service: usbccgp
| | Driver: usbccgp.sys, 6/17/2024 12:40:59, 191968 bytes
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 12/19/2023 15:16:44, 44032 bytes
| | | Driver: hidclass.sys, 12/19/2023 15:16:45, 233472 bytes
| | | Driver: hidparse.sys, 12/19/2023 15:16:45, 46080 bytes
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 12/7/2019 02:07:56, 46592 bytes
| | | | Driver: kbdclass.sys, 12/7/2019 02:07:56, 71480 bytes
| | | Service: HidUsb
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 12/7/2019 02:07:56, 35328 bytes
| | | | Driver: mouclass.sys, 12/7/2019 02:07:56, 67600 bytes
Gameport Devices
PS/2 Devices
| Service: kbdhid
| Service: kbdhid
| Service: mouhid
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 141.5 GB
Total Space: 241.1 GB
File System: NTFS
Model: SK hynix SC311 SATA 256GB
Drive: 😧
Model: PLDS DVD+-RW DU-8A5LH
Driver: C:\WINDOWS\SYSTEM32\DRIVERS\CDROM.SYS, 10.00.19041.4355 (English), 6/17/2024 12:40:58, 175616 bytes
System Devices
Name: Intel(R) Management Engine Interface #1
Device ID: PCI\VEN_8086&DEV_A13A&SUBSYS_06C71028&REV_31\3&11583659&0&B0
Driver: C:\windows\System32\DriverStore\FileRepository\heci.inf_amd64_6b6e8cc42a3d1f09\x64\TeeDriverW10x64.sys, 2406.05.0005.0000 (English), 2/11/2024 01:14:46, 323264 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_A170&SUBSYS_06C71028&REV_31\3&11583659&0&FB
Driver: C:\windows\system32\DRIVERS\hdaudbus.sys, 10.00.19041.4957 (English), 10/23/2024 11:51:06, 138752 bytes
Driver: C:\windows\system32\DRIVERS\drmk.sys, 10.00.19041.4648 (English), 10/23/2024 11:51:06, 97792 bytes
Driver: C:\windows\system32\DRIVERS\portcls.sys, 10.00.19041.4648 (English), 10/23/2024 11:51:06, 394240 bytes
Name: Intel(R) HD Graphics 630
Device ID: PCI\VEN_8086&DEV_5912&SUBSYS_06C71028&REV_04\3&11583659&0&10
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdkmd64.sys, 27.20.0100.8854 (English), 1/11/2021 20:18:00, 27572080 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iglhxs64.vp, 1/11/2021 19:39:20, 5556 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd10iumd64.dll, 27.20.0100.8854 (English), 1/11/2021 20:18:52, 22963080 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd11dxva64.dll, 27.20.0100.8854 (English), 1/11/2021 20:18:58, 77028256 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd12dxva64.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:12, 76810936 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd12umd64.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:16, 22061128 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdgmm64.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:50, 2489760 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxcmrt64.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:22, 211912 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfx11cmrt64.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:18, 215040 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdumdim64.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:14, 1449864 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdail64.dll, 1/11/2021 20:17:58, 192920 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd9dxva64.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:22, 76787536 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iga64.dll, 1/11/2021 20:18:32, 2775688 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igc64.dll, 27.20.0100.8854 (English), 1/11/2021 20:18:40, 46922224 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\UniversalAdapter64.dll, 1/11/2021 20:21:22, 505224 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\opencl-clang64.dll, 2.00.0008.0000 (English), 1/11/2021 20:21:20, 77848928 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdfcl64.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:36, 1004328 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdmd64.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:02, 12153776 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdml64.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:06, 4296112 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdde64.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:30, 418776 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdinfo64.dll, 1/11/2021 20:19:54, 153616 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdext64.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:34, 447512 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd10idpp64.dll, 27.20.0100.8854 (English), 1/11/2021 20:18:44, 143776 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd10iumd32.dll, 27.20.0100.8854 (English), 1/11/2021 20:18:48, 19707728 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd11dxva32.dll, 27.20.0100.8854 (English), 1/11/2021 20:18:56, 75705320 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd12dxva32.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:08, 75507816 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd12umd32.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:14, 21858432 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdgmm32.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:38, 1864928 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdumdim32.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:10, 1287240 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdail32.dll, 1/11/2021 20:17:58, 161176 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd9dxva32.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:18, 75477120 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxcmrt32.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:20, 171248 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfx11cmrt32.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:16, 173360 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iga32.dll, 1/11/2021 20:18:30, 2229608 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igc32.dll, 27.20.0100.8854 (English), 1/11/2021 20:18:34, 41028600 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\UniversalAdapter32.dll, 1/11/2021 20:21:22, 408776 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\opencl-clang32.dll, 2.00.0008.0000 (English), 1/11/2021 20:21:14, 58402064 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdfcl32.dll, 27.20.0100.8854 (English), 1/11/2021 20:18:00, 944536 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdmd32.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:58, 9722216 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdml32.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:04, 3244160 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdde32.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:26, 343160 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdinfo32.dll, 1/11/2021 20:19:52, 132128 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdext32.dll, 27.20.0100.8854 (English), 1/11/2021 20:19:34, 351576 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igd10idpp32.dll, 27.20.0100.8854 (English), 1/11/2021 20:18:42, 121256 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iglhxo64.vp, 1/11/2021 19:39:20, 42513 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iglhxc64.vp, 1/11/2021 19:39:20, 44194 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iglhxg64.vp, 1/11/2021 19:39:20, 43760 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iglhxo64_dev.vp, 1/11/2021 19:39:20, 43143 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iglhxc64_dev.vp, 1/11/2021 19:39:20, 43214 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iglhxg64_dev.vp, 1/11/2021 19:39:20, 43732 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iglhxa64.vp, 1/11/2021 19:39:20, 1125 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\iglhxa64.cpa, 1/11/2021 19:39:20, 1376256 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\IntelCpHDCPSvc.exe, 25.20.0100.8854 (English), 1/11/2021 20:18:20, 521072 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\cp_resources.bin, 1/11/2021 19:39:12, 2415596 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\difx64.exe, 1.04.0006.0000 (English), 1/11/2021 20:17:50, 265064 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxDH.dll, 6.15.0100.8854 (English), 1/11/2021 20:18:08, 975256 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxDI.dll, 6.15.0100.8854 (English), 1/11/2021 20:18:10, 416664 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxLHM.dll, 6.15.0100.8854 (English), 1/11/2021 20:18:14, 2257304 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxEM.exe, 6.15.0100.8854 (English), 1/11/2021 20:18:12, 887664 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxCUIServicePS.dll, 1/11/2021 20:18:06, 403352 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxCUIService.exe, 6.15.0100.8854 (English), 1/11/2021 20:18:06, 399216 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 1/11/2021 20:18:08, 115096 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 1/11/2021 20:18:14, 13720 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\GfxUIEx.exe, 6.15.0100.8854 (English), 1/11/2021 20:17:52, 505712 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\Gfxv4_0.exe, 8.15.0100.8854 (English), 1/11/2021 20:17:52, 1238896 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\GfxResources.dll, 8.15.0100.8854 (English), 1/11/2021 20:17:52, 9326488 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (English), 1/11/2021 20:18:28, 637336 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxCPL.cpl, 1/11/2021 20:18:06, 285592 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxDTCM.dll, 6.15.0100.8854 (English), 1/11/2021 20:18:10, 189848 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxext.exe, 6.15.0100.8854 (English), 1/11/2021 20:18:12, 344424 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxexps.dll, 6.15.0010.3682 (English), 1/11/2021 20:20:24, 49520 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\GfxDownloadWrapper.exe, 8.15.0100.8854 (English), 1/11/2021 20:17:50, 153968 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxSDK.exe, 1/11/2021 20:18:16, 982896 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxSDKLib.dll, 1.00.0000.0000 (Invariant Language), 1/11/2021 20:18:16, 91032 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\ColorImageEnhancement.wmv, 1/11/2021 19:39:12, 375173 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\ImageStabilization.wmv, 1/11/2021 19:39:20, 403671 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\FilmModeDetection.wmv, 1/11/2021 19:39:12, 641530 bytes
Driver: C:\windows\system32\igfxCPL.cpl, 1/11/2021 20:18:06, 285592 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igfxexps32.dll, 6.15.0010.3682 (English), 1/11/2021 20:18:12, 43928 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\ig9icd64.dll, 27.20.0100.8854 (English), 1/11/2021 20:17:56, 16512920 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\ig9icd32.dll, 27.20.0100.8854 (English), 1/11/2021 20:17:54, 13203352 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\OSSCOPYRIGHT, 1/11/2021 19:39:30, 1372 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igvk64.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:30, 19058120 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igvk64.json, 1/11/2021 19:39:20, 135 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\VulkanRT-EULA.txt, 1/11/2021 19:39:30, 4008 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igvk32.dll, 27.20.0100.8854 (English), 1/11/2021 20:20:28, 17258040 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igvk32.json, 1/11/2021 19:39:20, 135 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\vulkan-1-64.dll, 1.02.0148.0001 (English), 1/11/2021 20:18:34, 1087704 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\vulkaninfo-64.exe, 1.02.0148.0001 (English), 1/11/2021 20:18:36, 1781616 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\vulkan-1-32.dll, 1.02.0148.0001 (English), 1/11/2021 20:18:32, 940760 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\vulkaninfo-32.exe, 1.02.0148.0001 (English), 1/11/2021 20:18:34, 1377648 bytes
Driver: C:\windows\system32\vulkan-1.dll, 1.03.0275.0000 (English), 9/9/2024 16:25:50, 1445120 bytes
Driver: C:\windows\system32\vulkaninfo.exe, 1.03.0275.0000 (English), 9/9/2024 16:25:52, 2031496 bytes
Driver: C:\windows\system32\vulkan-1-999-0-0-0.dll, 1.03.0275.0000 (English), 9/9/2024 16:25:50, 1445120 bytes
Driver: C:\windows\system32\vulkaninfo-1-999-0-0-0.exe, 1.03.0275.0000 (English), 9/9/2024 16:25:52, 2031496 bytes
Driver: C:\windows\SysWow64\vulkan-1.dll, 1.03.0275.0000 (English), 9/9/2024 16:25:50, 1295104 bytes
Driver: C:\windows\SysWow64\vulkaninfo.exe, 1.03.0275.0000 (English), 9/9/2024 16:25:54, 1578752 bytes
Driver: C:\windows\SysWow64\vulkan-1-999-0-0-0.dll, 1.03.0275.0000 (English), 9/9/2024 16:25:50, 1295104 bytes
Driver: C:\windows\SysWow64\vulkaninfo-1-999-0-0-0.exe, 1.03.0275.0000 (English), 9/9/2024 16:25:54, 1578752 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\Intel_OpenCL_ICD32.dll, 2.02.0008.0000 (English), 1/11/2021 20:18:26, 361880 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdrcl32.dll, 23.20.0100.8854 (English), 1/11/2021 20:18:04, 4330392 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\Intel_OpenCL_ICD64.dll, 2.02.0008.0000 (English), 1/11/2021 20:18:26, 499096 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\ze_loader.dll, 1.00.0012.0000 (English), 1/11/2021 20:18:38, 419224 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\ze_validation_layer.dll, 1.00.0012.0000 (English), 1/11/2021 20:18:38, 140184 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igdrcl64.dll, 23.20.0100.8854 (English), 1/11/2021 20:18:04, 4936600 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\ze_intel_gpu64.dll, 1/11/2021 20:18:36, 4348824 bytes
Driver: C:\windows\SysWow64\OpenCL.dll, 3.00.0006.0000 (English), 9/9/2024 16:25:44, 374280 bytes
Driver: C:\windows\system32\OpenCL.dll, 3.00.0006.0000 (English), 9/9/2024 16:25:44, 477840 bytes
Driver: C:\windows\system32\ze_loader.dll, 1.00.0012.0000 (English), 1/11/2021 20:18:38, 419224 bytes
Driver: C:\windows\system32\ze_validation_layer.dll, 1.00.0012.0000 (English), 1/11/2021 20:18:38, 140184 bytes
Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 1/11/2021 20:20:42, 243152 bytes
Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 1.20.0009.0015 (English), 1/11/2021 20:18:28, 13511576 bytes
Driver: C:\Program Files\Intel\Media SDK\libmfxhw64.dll, 1/11/2021 20:20:44, 294776 bytes
Driver: C:\Program Files\Intel\Media SDK\mfxplugin64_hw.dll, 1.20.0009.0015 (English), 1/11/2021 20:18:30, 26668440 bytes
Driver: C:\windows\system32\intel_gfx_api-x64.dll, 10.20.0009.0015 (English), 1/11/2021 20:20:32, 161400 bytes
Driver: C:\windows\SysWow64\intel_gfx_api-x86.dll, 10.20.0009.0015 (English), 1/11/2021 20:20:34, 136904 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:04, 3203952 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:18:32, 3035544 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:08, 3225376 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9ve_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:12, 3217552 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_encrypt_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:00, 3000816 bytes
Driver: C:\Program Files\Intel\Media SDK\c_64.cpa, 10/31/2018 13:43:56, 1376256 bytes
Driver: C:\Program Files\Intel\Media SDK\cpa_64.vp, 1/11/2021 19:39:12, 1125 bytes
Driver: C:\Program Files\Intel\Media SDK\dev_64.vp, 1/11/2021 19:39:12, 56359 bytes
Driver: C:\Program Files\Intel\Media SDK\he_64.vp, 1/11/2021 19:39:12, 13661 bytes
Driver: C:\Program Files\Intel\Media SDK\mj_64.vp, 1/11/2021 19:39:28, 13393 bytes
Driver: C:\Program Files\Intel\Media SDK\h265e_64.vp, 1/11/2021 19:39:12, 14249 bytes
Driver: C:\Program Files\Intel\Media SDK\vp9e_64.vp, 1/11/2021 19:39:30, 14096 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:02, 2594400 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:18:30, 2454424 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:06, 2607432 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9ve_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:10, 2601728 bytes
Driver: C:\Program Files\Intel\Media SDK\mfx_mft_encrypt_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:20:56, 2436016 bytes
Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 10/31/2018 13:43:56, 1361159 bytes
Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 1/11/2021 19:39:12, 1125 bytes
Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 1/11/2021 19:39:12, 57143 bytes
Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 1/11/2021 19:39:12, 71553 bytes
Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 1/11/2021 19:39:28, 66901 bytes
Driver: C:\Program Files\Intel\Media SDK\h265e_32.vp, 1/11/2021 19:39:12, 73141 bytes
Driver: C:\Program Files\Intel\Media SDK\vp9e_32.vp, 1/11/2021 19:39:30, 72712 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\libmfxhw64.dll, 10.20.0009.0015 (English), 1/11/2021 20:20:38, 25260544 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfxplugin64_hw.dll, 1.20.0009.0015 (English), 1/11/2021 20:18:30, 26668440 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfxplugin64_av1e_gacc.dll, 1/11/2021 20:20:42, 7982864 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\intel_gfx_api-x64.dll, 10.20.0009.0015 (English), 1/11/2021 20:20:32, 161400 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\libmfxhw32.dll, 10.20.0009.0015 (English), 1/11/2021 20:20:36, 23783608 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfxplugin32_hw.dll, 1.20.0009.0015 (English), 1/11/2021 20:18:28, 13511576 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfxplugin32_av1e_gacc.dll, 1/11/2021 20:20:40, 6895504 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\intel_gfx_api-x86.dll, 10.20.0009.0015 (English), 1/11/2021 20:20:34, 136904 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_h264ve_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:02, 2594400 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_mjpgvd_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:18:30, 2454424 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_h265ve_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:06, 2607432 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_vp9ve_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:10, 2601728 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_encrypt_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:20:56, 2436016 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_av1hve_32.dll, 10.20.0009.0015 (English), 1/11/2021 20:20:52, 2604872 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\c_32.cpa, 1/11/2021 19:39:12, 1361159 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\cpa_32.vp, 1/11/2021 19:39:12, 1125 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\dev_32.vp, 1/11/2021 19:39:12, 57143 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\he_32.vp, 1/11/2021 19:39:12, 71553 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mj_32.vp, 1/11/2021 19:39:28, 66901 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\h265e_32.vp, 1/11/2021 19:39:12, 73141 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\vp9e_32.vp, 1/11/2021 19:39:30, 72712 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_av1hve_32.vp, 1/11/2021 19:39:28, 72825 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_h264ve_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:04, 3203952 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_mjpgvd_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:18:32, 3035544 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_h265ve_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:08, 3225376 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_vp9ve_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:12, 3217552 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_encrypt_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:21:00, 3000816 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_av1hve_64.dll, 10.20.0009.0015 (English), 1/11/2021 20:20:54, 3220184 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\c_64.cpa, 1/11/2021 19:39:12, 1376256 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\cpa_64.vp, 1/11/2021 19:39:12, 1125 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\dev_64.vp, 1/11/2021 19:39:12, 56359 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\he_64.vp, 1/11/2021 19:39:12, 13661 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mj_64.vp, 1/11/2021 19:39:28, 13393 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\h265e_64.vp, 1/11/2021 19:39:12, 14249 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\vp9e_64.vp, 1/11/2021 19:39:30, 14096 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\mfx_mft_av1hve_64.vp, 1/11/2021 19:39:28, 14085 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\IntelCpHeciSvc.exe, 9.01.0001.0920 (English), 1/11/2021 20:18:22, 504688 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_de4656412592a0a5\igxpco64.dll, 1.03.0027.0000 (English), 1/11/2021 20:18:18, 226200 bytes
Name: Intel(R) 100 Series/C230 Series Chipset Family Thermal subsystem - A131
Device ID: PCI\VEN_8086&DEV_A131&SUBSYS_06C71028&REV_31\3&11583659&0&A2
Driver: n/a
Name: Intel(R) Xeon(R) E3 - 1200 v6/7th Gen Intel(R) Core(TM) Host Bridge/DRAM Registers - 591F
Device ID: PCI\VEN_8086&DEV_591F&SUBSYS_06C71028&REV_05\3&11583659&0&00
Driver: n/a
Name: Intel(R) 100 Series/C230 Series Chipset Family SMBus - A123
Device ID: PCI\VEN_8086&DEV_A123&SUBSYS_06C71028&REV_31\3&11583659&0&FC
Driver: n/a
Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_A12F&SUBSYS_06C71028&REV_31\3&11583659&0&A0
Driver: C:\windows\system32\DRIVERS\USBXHCI.SYS, 10.00.19041.4355 (English), 6/17/2024 12:41:00, 620512 bytes
Driver: C:\windows\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.19041.4355 (English), 6/17/2024 12:41:00, 143792 bytes
Name: Intel(R) Chipset SATA/PCIe RST Premium Controller
Device ID: PCI\VEN_8086&DEV_2822&SUBSYS_06C71028&REV_31\3&11583659&0&B8
Driver: C:\windows\system32\DRIVERS\iaStorAC.sys, 17.11.0003.1010 (English), 12/18/2022 16:24:00, 1348760 bytes
Driver: C:\windows\system32\DRIVERS\iaStorAfs.sys, 17.11.0003.1010 (English), 12/18/2022 16:24:02, 74904 bytes
Driver: C:\windows\system32\iaStorAfsService.exe, 17.11.0003.1010 (English), 12/18/2022 16:24:04, 3104408 bytes
Driver: C:\windows\system32\iaStorAfsNative.exe, 17.11.0003.1010 (English), 12/18/2022 16:24:02, 221336 bytes
Driver: C:\windows\system32\OptaneEventLogMsg.dll, 17.11.0003.1010 (English), 12/18/2022 16:24:06, 25240 bytes
Driver: C:\windows\system32\Optane.dll, 17.11.0003.1010 (English), 12/18/2022 16:24:06, 115872 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\iastorac.inf_amd64_d6e4236a0f82e7b4\HfcDisableService.exe, 17.11.0003.1010 (English), 12/18/2022 16:23:58, 1918624 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\iastorac.inf_amd64_d6e4236a0f82e7b4\RstMwService.exe, 17.11.0003.1010 (English), 12/18/2022 16:24:10, 2245784 bytes
Driver: C:\windows\system32\RstMwEventLogMsg.dll, 17.11.0003.1010 (English), 12/18/2022 16:24:08, 28312 bytes
Name: Intel(R) 100 Series/C230 Series Chipset Family PMC - A121
Device ID: PCI\VEN_8086&DEV_A121&SUBSYS_06C71028&REV_31\3&11583659&0&FA
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0FB9&SUBSYS_11BC1028&REV_A1\4&511C2E8&0&0108
Name: Intel(R) Ethernet Connection (2) I219-LM
Device ID: PCI\VEN_8086&DEV_15B7&SUBSYS_06C71028&REV_31\3&11583659&0&FE
Driver: C:\windows\System32\DriverStore\FileRepository\e1d.inf_amd64_a9790eceb25abaff\e1d.sys, 12.19.0002.0057 (English), 5/22/2024 23:23:48, 622160 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\e1d.inf_amd64_a9790eceb25abaff\e1dmsg.dll, 10.00.0940.0000 (English), 5/22/2024 23:23:52, 42168 bytes
Name: NVIDIA Quadro P1000
Device ID: PCI\VEN_10DE&DEV_1CB1&SUBSYS_11BC1028&REV_A1\4&511C2E8&0&0008
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0000.ui.forms, 9/9/2024 15:52:22, 62846 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0000.ui.strings, 9/9/2024 15:52:22, 1404 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0401.ui.forms, 9/9/2024 15:52:22, 4333 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0401.ui.strings, 9/9/2024 15:52:22, 11869 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0404.ui.forms, 9/9/2024 15:52:22, 4659 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0404.ui.strings, 9/9/2024 15:52:22, 9832 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0405.ui.forms, 9/9/2024 15:52:22, 4748 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0405.ui.strings, 9/9/2024 15:52:22, 10447 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0406.ui.forms, 9/9/2024 15:52:22, 4581 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0406.ui.strings, 9/9/2024 15:52:22, 10155 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0407.ui.forms, 9/9/2024 15:52:22, 6411 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0407.ui.strings, 9/9/2024 15:52:22, 11080 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0408.ui.forms, 9/9/2024 15:52:22, 7052 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0408.ui.strings, 9/9/2024 15:52:22, 14674 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0409.ui.forms, 9/9/2024 15:52:22, 4423 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0409.ui.strings, 9/9/2024 15:52:22, 9793 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\040a.ui.forms, 9/9/2024 15:52:22, 5186 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\040a.ui.strings, 9/9/2024 15:52:22, 10494 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\040b.ui.forms, 9/9/2024 15:52:22, 6012 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\040b.ui.strings, 9/9/2024 15:52:22, 10281 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\040c.ui.forms, 9/9/2024 15:52:22, 6957 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\040c.ui.strings, 9/9/2024 15:52:22, 10961 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\040d.ui.forms, 9/9/2024 15:52:22, 4522 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\040d.ui.strings, 9/9/2024 15:52:22, 11947 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\040e.ui.forms, 9/9/2024 15:52:22, 4515 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\040e.ui.strings, 9/9/2024 15:52:22, 10581 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0410.ui.forms, 9/9/2024 15:52:22, 4704 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0410.ui.strings, 9/9/2024 15:52:22, 10663 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0411.ui.forms, 9/9/2024 15:52:22, 4700 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0411.ui.strings, 9/9/2024 15:52:22, 11960 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0412.ui.forms, 9/9/2024 15:52:22, 4567 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0412.ui.strings, 9/9/2024 15:52:22, 10753 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0413.ui.forms, 9/9/2024 15:52:22, 5913 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0413.ui.strings, 9/9/2024 15:52:22, 10483 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0414.ui.forms, 9/9/2024 15:52:22, 4770 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0414.ui.strings, 9/9/2024 15:52:22, 10128 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0415.ui.forms, 9/9/2024 15:52:22, 7010 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0415.ui.strings, 9/9/2024 15:52:22, 10478 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0416.ui.forms, 9/9/2024 15:52:22, 5603 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0416.ui.strings, 9/9/2024 15:52:22, 10330 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0419.ui.forms, 9/9/2024 15:52:22, 6039 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0419.ui.strings, 9/9/2024 15:52:22, 13264 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\041b.ui.forms, 9/9/2024 15:52:22, 4730 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\041b.ui.strings, 9/9/2024 15:52:22, 10605 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\041d.ui.forms, 9/9/2024 15:52:22, 4720 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\041d.ui.strings, 9/9/2024 15:52:22, 10158 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\041e.ui.forms, 9/9/2024 15:52:22, 5929 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\041e.ui.strings, 9/9/2024 15:52:22, 16846 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\041f.ui.forms, 9/9/2024 15:52:22, 5213 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\041f.ui.strings, 9/9/2024 15:52:22, 10289 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0422.ui.forms, 9/9/2024 15:52:22, 5530 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0422.ui.strings, 9/9/2024 15:52:22, 14173 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0424.ui.forms, 9/9/2024 15:52:22, 5495 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0424.ui.strings, 9/9/2024 15:52:22, 10314 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0804.ui.strings, 9/9/2024 15:52:22, 9275 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0809.ui.strings, 9/9/2024 15:52:22, 9761 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\080a.ui.strings, 9/9/2024 15:52:22, 10482 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0816.ui.forms, 9/9/2024 15:52:22, 5650 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\0816.ui.strings, 9/9/2024 15:52:22, 10660 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\DisplayDriver.nvi, 9/9/2024 15:52:22, 94161 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\DisplayDriverExt.dll, 2.1002.0418.0000 (English), 9/9/2024 16:21:18, 1905680 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\EULA.txt, 9/9/2024 15:52:22, 21691 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NVGPUP.Container.exe, 1.39.3323.1171 (English), 9/9/2024 16:22:38, 1275000 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NVI2.dll, 2.1002.0418.0000 (English), 9/9/2024 16:22:42, 6787728 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NVI2UI.dll, 2.1002.0418.0000 (English), 9/9/2024 16:22:44, 2019496 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NVPrxy32.dll, 2.1002.0418.0000 (English), 9/9/2024 16:24:06, 1197168 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NVPrxy64.dll, 2.1002.0418.0000 (English), 9/9/2024 16:24:06, 1555592 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCCX.dll, 9/9/2024 16:21:36, 1393160 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvInstallerUtil.dll, 18.00.0003.0000 (English), 9/9/2024 16:22:48, 4536328 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\box_checked_disabled.png, 9/9/2024 15:52:22, 937 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\box_checked_enabled.png, 9/9/2024 15:52:22, 821 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\box_partialcheckboxed_enabled.png, 9/9/2024 15:52:22, 3208 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\box_unchecked_disabled.png, 9/9/2024 15:52:22, 180 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\box_unchecked_enabled.png, 9/9/2024 15:52:22, 701 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_disable_135.png, 9/9/2024 15:52:22, 720 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_disable_180.png, 9/9/2024 15:52:22, 738 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_disable_90.png, 9/9/2024 15:52:22, 705 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_primary_135.png, 9/9/2024 15:52:22, 870 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_primary_180.png, 9/9/2024 15:52:22, 894 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_primary_90.png, 9/9/2024 15:52:22, 852 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_primary_focus_135.png, 9/9/2024 15:52:22, 882 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_primary_focus_180.png, 9/9/2024 15:52:22, 908 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_primary_focus_90.png, 9/9/2024 15:52:22, 863 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_primary_pressed_135.png, 9/9/2024 15:52:22, 842 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_primary_pressed_180.png, 9/9/2024 15:52:22, 867 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_primary_pressed_90.png, 9/9/2024 15:52:22, 822 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_secondary_135.png, 9/9/2024 15:52:22, 815 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_secondary_180.png, 9/9/2024 15:52:22, 833 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_secondary_90.png, 9/9/2024 15:52:22, 796 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_secondary_focus_135.png, 9/9/2024 15:52:22, 801 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_secondary_focus_180.png, 9/9/2024 15:52:22, 824 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_secondary_focus_90.png, 9/9/2024 15:52:22, 789 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_secondary_pressed_135.png, 9/9/2024 15:52:22, 819 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_secondary_pressed_180.png, 9/9/2024 15:52:22, 841 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\btn_secondary_pressed_90.png, 9/9/2024 15:52:22, 803 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\check.png, 9/9/2024 15:52:22, 731 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\checkmark.png, 9/9/2024 15:52:22, 641 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\circled_checkmark.png, 9/9/2024 15:52:22, 2970 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\dbInstaller.exe, 32.00.0015.5612 (English), 9/9/2024 16:21:18, 822416 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\error.png, 9/9/2024 15:52:22, 2531 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\flxconnect64.dll, 2018.02.0001.0000 (English), 9/9/2024 16:21:18, 6595264 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\flxcore64.dll, 2018.02.0001.0000 (English), 9/9/2024 16:21:22, 8968896 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\grid-proxy-credentials.ps1, 9/9/2024 15:52:22, 4592 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\grid-third-party-licenses.txt, 9/9/2024 15:52:22, 107281 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\info.png, 9/9/2024 15:52:22, 2191 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\install_bg.png, 9/9/2024 15:52:22, 62330 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\install_bg_rtl.png, 9/9/2024 15:52:22, 63022 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\license.txt, 9/9/2024 15:52:24, 42602 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\mcu.exe, 1.01.5204.20580 (English), 9/9/2024 16:21:26, 853664 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvapi.dll, 32.00.0015.5612 (English), 9/9/2024 16:20:42, 6142720 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvapi64.dll, 32.00.0015.5612 (English), 9/9/2024 16:20:44, 7061976 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvcuda_loader32.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:52, 6914696 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvcuda_loader64.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:56, 3788936 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvcudadebugger.dll, 0.00.0000.0000 (English), 9/9/2024 16:21:50, 5867656 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvcuvid32.dll, 7.17.0015.5612 (English), 9/9/2024 16:21:58, 16119432 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvcuvid64.dll, 7.17.0015.5612 (English), 9/9/2024 16:22:02, 13009032 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdebugdump.exe, 6.14.0015.5612 (English), 9/9/2024 16:22:06, 460936 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdrsdb.bin, 9/9/2024 15:52:24, 1976292 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdw.inf, 9/9/2024 15:52:24, 529033 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvencodeapi.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:28, 795664 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvencodeapi64.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:30, 1033384 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvfbc.dll, 6.14.0015.5612 (English), 9/9/2024 16:22:30, 1631368 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvfbc64.dll, 6.14.0015.5612 (English), 9/9/2024 16:22:32, 2180720 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvidia-smi.exe, 8.17.0015.5612 (English), 9/9/2024 16:22:46, 847992 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvifr.dll, 6.14.0015.5612 (English), 9/9/2024 16:22:46, 1204744 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvifr64.dll, 6.14.0015.5612 (English), 9/9/2024 16:22:48, 1549456 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvinfo.pb, 9/9/2024 15:52:24, 123973 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvml_loader.dll, 8.17.0015.5612 (English), 9/9/2024 16:23:06, 1068688 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvofapi.dll, 32.00.0015.5612 (English), 9/9/2024 16:23:10, 506016 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvofapi64.dll, 32.00.0015.5612 (English), 9/9/2024 16:23:12, 670368 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvpciflt.sys, 32.00.0015.5612 (English), 9/9/2024 16:24:04, 56456 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvsetup.exe, 9/9/2024 16:24:38, 87688 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvvgpu64.dll, 6.14.0015.5612 (English), 9/9/2024 16:24:54, 2001552 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvvgpuconfig.dll, 32.00.0015.5612 (English), 9/9/2024 16:24:54, 295032 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvvgpugsp64.dll, 6.14.0015.5612 (English), 9/9/2024 16:24:56, 1383544 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\opencl32.dll, 3.00.0006.0000 (English), 9/9/2024 16:25:44, 374280 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\opencl64.dll, 3.00.0006.0000 (English), 9/9/2024 16:25:44, 477840 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\presentations_bg.png, 9/9/2024 15:52:34, 143326 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\presentations_bg_rtl.png, 9/9/2024 15:52:34, 140906 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\radio_btn_selected.png, 9/9/2024 15:52:34, 1718 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\radio_btn_unselected.png, 9/9/2024 15:52:34, 1516 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\setup.cfg, 9/9/2024 15:52:34, 13099 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\setup.exe, 2.1002.0418.0000 (English), 9/9/2024 16:25:46, 660624 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\splash.png, 9/9/2024 15:52:34, 161756 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\splash_rtl.png, 9/9/2024 15:52:34, 164925 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\theme.cfg, 9/9/2024 15:52:34, 9085 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\uninstall_bg.png, 9/9/2024 15:52:34, 64596 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\uninstall_bg_rtl.png, 9/9/2024 15:52:34, 62297 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\vgpuconfig-azure_hci.xml, 9/9/2024 15:52:34, 284608 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\vgpuconfig-azure_hci_aie.xml, 9/9/2024 15:52:34, 372509 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\vgpuconfig.xml, 9/9/2024 15:52:34, 318930 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\vulkan-1-x64.dll, 1.03.0275.0000 (English), 9/9/2024 16:25:50, 1445120 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\vulkan-1-x86.dll, 1.03.0275.0000 (English), 9/9/2024 16:25:50, 1295104 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\vulkaninfo-x64.exe, 1.03.0275.0000 (English), 9/9/2024 16:25:52, 2031496 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\vulkaninfo-x86.exe, 1.03.0275.0000 (English), 9/9/2024 16:25:54, 1578752 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\warning.png, 9/9/2024 15:52:34, 1601 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NVWMI\nvPerfProvider.man, 9/9/2024 15:52:36, 14175 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NVWMI\nvWmi.mof, 9/9/2024 15:52:36, 148921 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NVWMI\nvWmi64.exe, 2.36.0000.0000 (English), 9/9/2024 16:26:22, 4525704 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\NVDisplay.Container.exe, 1.39.3323.1171 (English), 9/9/2024 16:25:56, 1274896 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\NvContainerRecovery.bat, 9/9/2024 15:52:34, 1951 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\NvMessageBus.dll, 3.12.3354.5005 (English), 9/9/2024 16:25:58, 3493536 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\dlsargs.xml, 9/9/2024 15:52:34, 544 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\dlsnetparams.csv, 9/9/2024 15:52:34, 201870 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\messagebus_client.conf, 9/9/2024 15:52:34, 313 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\nvgwls.exe, 9/9/2024 16:25:56, 3727016 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\nvtopps.db3, 9/9/2024 15:52:34, 126976 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\LocalSystem\NvXDCore.dll, 32.00.0015.5612 (English), 9/9/2024 16:26:00, 1901064 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\LocalSystem\NvcDispCorePlugin.dll, 32.00.0015.5612 (English), 9/9/2024 16:25:58, 521888 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\LocalSystem\NvcDispWatchdog.dll, 1.39.3323.1171 (English), 9/9/2024 16:26:00, 759952 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\LocalSystem\_DisplayDriverRAS.dll, 1.10.0000.0000 (English), 9/9/2024 16:26:02, 2547848 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\LocalSystem\_NvMsgBusBroadcast.dll, 3.12.3354.5005 (English), 9/9/2024 16:26:02, 3491488 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\LocalSystem\_nvtopps.dll, 32.00.0015.5612 (English), 9/9/2024 16:26:04, 11673768 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\LocalSystem\messagebus.conf, 9/9/2024 15:52:34, 313 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\LocalSystem\wksServicePluginZ.dll, 32.00.0015.5612 (English), 9/9/2024 16:26:02, 280176 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\Session\_NvGSTPlugin.dll, 32.00.0015.5612 (English), 9/9/2024 16:26:08, 2653864 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\Session\nvprofileupdaterplugin.dll, 32.00.0015.5612 (English), 9/9/2024 16:26:04, 1977504 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\Session\nvxdsyncplugin.dll, 8.17.0015.5612 (English), 9/9/2024 16:26:06, 1842208 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\Display.NvContainer\plugins\Session\wksServicePlugin.dll, 32.00.0015.5612 (English), 9/9/2024 16:26:06, 314400 bytes
Driver: C:\windows\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 32.00.0015.5612 (English), 9/9/2024 16:21:18, 822416 bytes
Driver: C:\windows\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 9/9/2024 15:52:24, 1976292 bytes
Driver: C:\windows\system32\nvcpl.dll, 8.17.0015.5612 (English), 9/9/2024 16:21:38, 5914248 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nv3dappshext.dll, 6.14.0015.5612 (English), 9/9/2024 16:21:28, 1004688 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nv3dappshextr.dll, 6.14.0015.5612 (English), 9/9/2024 16:21:28, 97800 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvcoproc.bin, 9/9/2024 15:52:24, 10640137 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvcpl.dll, 8.17.0015.5612 (English), 9/9/2024 16:21:38, 5914248 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdevtools.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:10, 4598920 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdevtoolsr.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:10, 245360 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdisps.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:12, 11664008 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdispsr.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:14, 11575408 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvgames.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:34, 12498592 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvgamesr.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:34, 13321224 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvlicensings.dll, 6.14.0015.5612 (English), 9/9/2024 16:23:02, 4580512 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvlicensingsr.dll, 6.14.0015.5612 (English), 9/9/2024 16:23:04, 363016 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvshext.dll, 1.02.0000.0001 (English), 9/9/2024 16:24:40, 133768 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvsmartmax.dll, 6.14.0010.10003 (English), 9/9/2024 16:24:40, 199280 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvsmartmax64.dll, 6.14.0010.10003 (English), 9/9/2024 16:24:40, 236656 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvsmartmaxapp.exe, 6.14.0010.10003 (English), 9/9/2024 16:24:42, 273928 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvsmartmaxapp64.exe, 6.14.0010.10003 (English), 9/9/2024 16:24:42, 285320 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvsvc64.dll, 32.00.0015.5612 (English), 9/9/2024 16:24:44, 2674320 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvsvcr.dll, 32.00.0015.5612 (English), 9/9/2024 16:24:46, 1801360 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvsvs.dll, 32.00.0015.5612 (English), 9/9/2024 16:24:46, 5107848 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvsvsr.dll, 32.00.0015.5612 (English), 9/9/2024 16:24:48, 2011768 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvui.dll, 8.17.0015.5612 (English), 9/9/2024 16:24:50, 6658696 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvuir.dll, 8.17.0015.5612 (English), 9/9/2024 16:24:52, 2649224 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvvitvs.dll, 32.00.0015.5612 (English), 9/9/2024 16:24:56, 7468200 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvvitvsr.dll, 32.00.0015.5612 (English), 9/9/2024 16:24:58, 4263432 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvwss.dll, 32.00.0015.5612 (English), 9/9/2024 16:25:32, 12276392 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvwssr.dll, 32.00.0015.5612 (English), 9/9/2024 16:25:34, 9529352 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvxdapix.dll, 8.17.0015.5612 (English), 9/9/2024 16:25:38, 9426976 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvxdbat.dll, 8.17.0015.5612 (English), 9/9/2024 16:25:40, 1655440 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvxdplcy.dll, 8.17.0015.5612 (English), 9/9/2024 16:25:42, 1897104 bytes
Driver: C:\windows\system32\lxss\lib\libcuda.so, 9/9/2024 15:52:22, 162608 bytes
Driver: C:\windows\system32\lxss\lib\libcuda.so.1, 9/9/2024 15:52:22, 162608 bytes
Driver: C:\windows\system32\lxss\lib\libcuda.so.1.1, 9/9/2024 15:52:22, 162608 bytes
Driver: C:\windows\system32\lxss\lib\libcudadebugger.so.1, 9/9/2024 15:52:22, 10678152 bytes
Driver: C:\windows\system32\lxss\lib\libnvcuvid.so, 9/9/2024 15:52:22, 11804024 bytes
Driver: C:\windows\system32\lxss\lib\libnvcuvid.so.1, 9/9/2024 15:52:22, 11804024 bytes
Driver: C:\windows\system32\lxss\lib\libnvdxdlkernels.so, 9/9/2024 15:52:22, 120402144 bytes
Driver: C:\windows\system32\lxss\lib\libnvidia-encode.so, 9/9/2024 15:52:22, 580200 bytes
Driver: C:\windows\system32\lxss\lib\libnvidia-encode.so.1, 9/9/2024 15:52:22, 580200 bytes
Driver: C:\windows\system32\lxss\lib\libnvidia-ml.so.1, 9/9/2024 15:52:22, 245016 bytes
Driver: C:\windows\system32\lxss\lib\libnvidia-opticalflow.so, 9/9/2024 15:52:22, 362960 bytes
Driver: C:\windows\system32\lxss\lib\libnvidia-opticalflow.so.1, 9/9/2024 15:52:22, 362960 bytes
Driver: C:\windows\system32\lxss\lib\libnvoptix.so.1, 9/9/2024 15:52:24, 72664 bytes
Driver: C:\windows\system32\lxss\lib\libnvwgf2umx.so, 9/9/2024 15:52:24, 66707672 bytes
Driver: C:\windows\system32\lxss\lib\nvidia-smi, 9/9/2024 15:52:24, 719392 bytes
Driver: C:\windows\system32\DRIVERS\NVIDIA Corporation\license.txt, 9/9/2024 15:52:24, 42602 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\FreqTransfer32.exe, 9/9/2024 16:26:10, 3764232 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\FreqTransfer64.exe, 9/9/2024 16:26:10, 4057232 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\GreenScreenBG01.jpg, 9/9/2024 15:52:36, 281528 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\GreenScreenBG02.jpg, 9/9/2024 15:52:36, 499736 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\HighresBlender32.exe, 9/9/2024 16:26:12, 3860488 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\HighresBlender64.exe, 9/9/2024 16:26:12, 4163080 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\NvCamera32.dll, 7.01.0000.0000 (English), 9/9/2024 16:26:14, 8192880 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\NvCamera64.dll, 7.01.0000.0000 (English), 9/9/2024 16:26:14, 8697480 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\NvCameraAllowlisting32.dll, 7.01.0000.0000 (English), 9/9/2024 16:26:16, 520256 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\NvCameraAllowlisting64.dll, 7.01.0000.0000 (English), 9/9/2024 16:26:16, 666640 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\NvCameraEnable.exe, 9/9/2024 16:26:18, 375456 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\NvImageConvert32.exe, 9/9/2024 16:26:18, 3764256 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\NvImageConvert64.exe, 9/9/2024 16:26:18, 4038312 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\ReShadeFXC32.exe, 2.00.0000.0000 (English), 9/9/2024 16:26:20, 776848 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\ReShadeFXC64.exe, 2.00.0000.0000 (English), 9/9/2024 16:26:20, 892064 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\ShotWithGeforce518x32.rgba, 9/9/2024 15:52:36, 66304 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\SphericalEquirect32.exe, 9/9/2024 16:26:22, 3716616 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\SphericalEquirect64.exe, 9/9/2024 16:26:22, 3940976 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\Sticker01.png, 9/9/2024 15:52:36, 49695 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\Sticker02.png, 9/9/2024 15:52:36, 474002 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\Sticker03.png, 9/9/2024 15:52:36, 380006 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\Sticker04.png, 9/9/2024 15:52:36, 86881 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\Sticker05.png, 9/9/2024 15:52:36, 59304 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\Sticker06.png, 9/9/2024 15:52:36, 13547 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\Sticker07.png, 9/9/2024 15:52:36, 6342 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\Sticker08.png, 9/9/2024 15:52:36, 96493 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\d3dcompiler_47_32.dll, 6.03.9600.16384 (English), 9/9/2024 16:26:08, 3471392 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\d3dcompiler_47_64.dll, 6.03.9600.16384 (English), 9/9/2024 16:26:08, 4177928 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\scratches.jpg, 9/9/2024 15:52:36, 346354 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\tools_licenses.txt, 9/9/2024 15:52:36, 15970 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvCamera\ui.tga, 9/9/2024 15:52:36, 120236 bytes
Driver: C:\windows\system32\MCU.exe, 1.01.5204.20580 (English), 9/9/2024 16:21:26, 853664 bytes
Driver: C:\windows\system32\nvdebugdump.exe, 6.14.0015.5612 (English), 9/9/2024 16:22:06, 460936 bytes
Driver: C:\windows\system32\nvidia-smi.exe, 8.17.0015.5612 (English), 9/9/2024 16:22:46, 847992 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvopencl32.dll, 32.00.0015.5612 (English), 9/9/2024 16:23:30, 18108048 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvopencl64.dll, 32.00.0015.5612 (English), 9/9/2024 16:23:36, 10652816 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvlddmkm.sys, 32.00.0015.5612 (English), 9/9/2024 16:22:50, 60689568 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvvm32.dll, 32.00.0015.5612 (English), 9/9/2024 16:25:00, 60463136 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvvm64.dll, 32.00.0015.5612 (English), 9/9/2024 16:25:16, 68368520 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\gsp_ga10x.bin, 9/9/2024 15:52:22, 35374624 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\gsp_tu10x.bin, 9/9/2024 15:52:22, 25089688 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libcuda.so.1.1, 9/9/2024 15:52:22, 8433768 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libcuda_loader.so, 9/9/2024 15:52:22, 162608 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libcudadebugger.so.1, 9/9/2024 15:52:22, 10678152 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvcuvid.so.1, 9/9/2024 15:52:22, 11804024 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvdxdlkernels.so, 9/9/2024 15:52:22, 120402144 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvdxgdmal.so.1, 9/9/2024 15:52:22, 51200 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvidia-encode.so.1, 9/9/2024 15:52:22, 580200 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvidia-ml.so.1, 9/9/2024 15:52:22, 1730248 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvidia-ml_loader.so, 9/9/2024 15:52:22, 245016 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvidia-nvvm.so.4, 9/9/2024 15:52:22, 28139672 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvidia-opticalflow.so.1, 9/9/2024 15:52:22, 362960 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvidia-ptxjitcompiler.so.1, 9/9/2024 15:52:24, 29387176 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvoptix_loader.so.1, 9/9/2024 15:52:24, 72664 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\libnvwgf2umx.so, 9/9/2024 15:52:24, 66707672 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nv-vk64.json, 9/9/2024 15:52:24, 674 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvAIDVC.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:30, 2553864 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvAIDVCx.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:30, 2673800 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvAIHDR.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:32, 2853896 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvAIHDRx.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:34, 2982536 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvDecMFTMjpeg.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:08, 508024 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvDecMFTMjpegx.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:08, 658552 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvEncMFTH264.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:24, 916648 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvEncMFTH264x.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:26, 1167392 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvEncMFThevc.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:26, 923784 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvEncMFThevcx.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:28, 1179168 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvcubins.bin, 9/9/2024 15:52:24, 24887216 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvcuda32.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:40, 22276240 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvcuda64.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:46, 9920120 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvd3dumx.dll, 32.00.0015.5612 (English), 9/9/2024 16:20:58, 33990832 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdlistx.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:06, 242344 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdlppx.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:08, 13421072 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdxdlkernels.dll, 9/9/2024 16:22:20, 125616784 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdxgdmal32.dll, 9/9/2024 16:22:20, 467576 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdxgdmal64.dll, 9/9/2024 16:22:20, 596592 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvgpucomp32.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:12, 26546208 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvgpucomp64.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:20, 32058200 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvidia-smi, 9/9/2024 15:52:24, 719392 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvldumdx.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:30, 799240 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvml.dll, 8.17.0015.5612 (English), 9/9/2024 16:23:06, 1619488 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvoglv64.dll, 32.00.0015.5612 (English), 9/9/2024 16:23:20, 39130272 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvoptix.bin, 9/9/2024 15:52:34, 99616380 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvoptix.dll, 8.01.0000.0000 (English), 9/9/2024 16:23:44, 89154080 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvppe.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:30, 931088 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvppex.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:32, 1416424 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvptxJitCompiler32.dll, 32.00.0015.5612 (English), 9/9/2024 16:24:08, 17727608 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvptxJitCompiler64.dll, 32.00.0015.5612 (English), 9/9/2024 16:24:12, 20492920 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvrtum64.dll, 32.00.0015.5612 (English), 9/9/2024 16:24:20, 70979704 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvwgf2umx.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:50, 62961280 bytes
Driver: C:\windows\system32\NvFBC64.dll, 6.14.0015.5612 (English), 9/9/2024 16:22:32, 2180720 bytes
Driver: C:\windows\system32\NvIFR64.dll, 6.14.0015.5612 (English), 9/9/2024 16:22:48, 1549456 bytes
Driver: C:\windows\system32\nvEncodeAPI64.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:30, 1033384 bytes
Driver: C:\windows\system32\nvapi64.dll, 32.00.0015.5612 (English), 9/9/2024 16:20:44, 7061976 bytes
Driver: C:\windows\system32\nvcuda.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:56, 3788936 bytes
Driver: C:\windows\system32\nvcudadebugger.dll, 0.00.0000.0000 (English), 9/9/2024 16:21:50, 5867656 bytes
Driver: C:\windows\system32\nvcuvid.dll, 7.17.0015.5612 (English), 9/9/2024 16:22:02, 13009032 bytes
Driver: C:\windows\system32\nvinfo.pb, 9/9/2024 15:52:24, 123973 bytes
Driver: C:\windows\system32\nvml.dll, 8.17.0015.5612 (English), 9/9/2024 16:23:06, 1068688 bytes
Driver: C:\windows\system32\nvofapi64.dll, 32.00.0015.5612 (English), 9/9/2024 16:23:12, 670368 bytes
Driver: C:\windows\system32\vulkan-1-999-0-0-0.dll, 1.03.0275.0000 (English), 9/9/2024 16:25:50, 1445120 bytes
Driver: C:\windows\system32\vulkan-1.dll, 1.03.0275.0000 (English), 9/9/2024 16:25:50, 1445120 bytes
Driver: C:\windows\system32\vulkaninfo-1-999-0-0-0.exe, 1.03.0275.0000 (English), 9/9/2024 16:25:52, 2031496 bytes
Driver: C:\windows\system32\vulkaninfo.exe, 1.03.0275.0000 (English), 9/9/2024 16:25:52, 2031496 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nv-vk32.json, 9/9/2024 15:52:24, 674 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvIccAdvancedColorIdentity.icm, 9/9/2024 15:52:24, 3288 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvd3dum.dll, 32.00.0015.5612 (English), 9/9/2024 16:20:48, 33032760 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdispco64.exe, 1.00.0016.0000 (English), 9/9/2024 16:22:12, 1738872 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvdlist.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:06, 205408 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvldumd.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:30, 640792 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvoglv32.dll, 32.00.0015.5612 (English), 9/9/2024 16:23:14, 24322080 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\nvwgf2um.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:36, 48014152 bytes
Driver: C:\windows\SysWow64\NvFBC.dll, 6.14.0015.5612 (English), 9/9/2024 16:22:30, 1631368 bytes
Driver: C:\windows\SysWow64\NvIFR.dll, 6.14.0015.5612 (English), 9/9/2024 16:22:46, 1204744 bytes
Driver: C:\windows\SysWow64\OpenCL.dll, 3.00.0006.0000 (English), 9/9/2024 16:25:44, 374280 bytes
Driver: C:\windows\SysWow64\nvEncodeAPI.dll, 32.00.0015.5612 (English), 9/9/2024 16:22:28, 795664 bytes
Driver: C:\windows\SysWow64\nvapi.dll, 32.00.0015.5612 (English), 9/9/2024 16:20:42, 6142720 bytes
Driver: C:\windows\SysWow64\nvcuda.dll, 32.00.0015.5612 (English), 9/9/2024 16:21:52, 6914696 bytes
Driver: C:\windows\SysWow64\nvcuvid.dll, 7.17.0015.5612 (English), 9/9/2024 16:21:58, 16119432 bytes
Driver: C:\windows\SysWow64\nvofapi.dll, 32.00.0015.5612 (English), 9/9/2024 16:23:10, 506016 bytes
Driver: C:\windows\SysWow64\vulkan-1-999-0-0-0.dll, 1.03.0275.0000 (English), 9/9/2024 16:25:50, 1295104 bytes
Driver: C:\windows\SysWow64\vulkan-1.dll, 1.03.0275.0000 (English), 9/9/2024 16:25:50, 1295104 bytes
Driver: C:\windows\SysWow64\vulkaninfo-1-999-0-0-0.exe, 1.03.0275.0000 (English), 9/9/2024 16:25:54, 1578752 bytes
Driver: C:\windows\SysWow64\vulkaninfo.exe, 1.03.0275.0000 (English), 9/9/2024 16:25:54, 1578752 bytes
Driver: C:\windows\System32\DriverStore\FileRepository\nvdw.inf_amd64_df7d38d923ade95b\NvTelemetry64.dll, 14.03.0060.0000 (English), 9/9/2024 16:24:48, 4466232 bytes
Name: Intel(R) 100 Series/C230 Series Chipset Family LPC Controller (C236) - A149
Device ID: PCI\VEN_8086&DEV_A149&SUBSYS_06C71028&REV_31\3&11583659&0&F8
Driver: C:\windows\system32\DRIVERS\msisadrv.sys, 10.00.19041.3636 (English), 12/19/2023 15:16:41, 21480 bytes
Name: Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x16) - 1901
Device ID: PCI\VEN_8086&DEV_1901&SUBSYS_06C71028&REV_05\3&11583659&0&08
Driver: C:\windows\system32\DRIVERS\pci.sys, 10.00.19041.4842 (English), 10/23/2024 11:51:07, 479736 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.19041.3636
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.19041.3636
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.19041.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.19041.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.19041.3636
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.19041.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.19041.3996
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.19041.3636
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.19041.3636
DV Muxer,0x00400000,0,0,qdv.dll,10.00.19041.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.19041.3636
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.19041.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.19041.3636
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.19041.3636
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.19041.5007
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.19041.3636
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.19041.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.3636
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.19041.3636
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.19041.3636
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.19041.3636
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.19041.3636
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.19041.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.19041.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.4355
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.19041.3636
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.19041.3636
DV Splitter,0x00600000,1,2,qdv.dll,10.00.19041.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.19041.3636
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.19041.4355
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.19041.3636
Video Renderer,0x00800001,1,0,quartz.dll,10.00.19041.3636
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.19041.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.19041.3636
Video Renderer,0x00400000,1,0,quartz.dll,10.00.19041.3636
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.19041.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.19041.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.19041.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.19041.3636
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.19041.3636
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.4355
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.19041.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.19041.3636
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.19041.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.19041.4355
Null Renderer,0x00200000,1,0,qedit.dll,10.00.19041.4355
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.19041.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.19041.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.19041.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.19041.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.3636
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.19041.3636
Wave Parser,0x00400000,1,1,quartz.dll,10.00.19041.3636
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.19041.3636
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.19041.3636
File stream renderer,0x00400000,1,1,quartz.dll,10.00.19041.3636
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.19041.4355
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.19041.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.19041.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.19041.3636
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.19041.3636
File Source (URL),0x00400000,0,1,quartz.dll,10.00.19041.3636
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.19041.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.19041.4355
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.19041.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.19041.3636
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.19041.4355
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.19041.3636
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.19041.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.19041.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.19041.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.19041.3636
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.19041.3636
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.19041.3636
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.3636
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.3636
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.19041.3636
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.19041.3636
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.19041.3636
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.19041.3636
Audio Capture Sources:
Microphone (HD Web Camera),0x00200000,0,0,qcap.dll,10.00.19041.0001
Microphone (HoverCam Solo8+ (Audio)),0x00200000,0,0,qcap.dll,10.00.19041.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.19041.4842
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.4842
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.4842
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.19041.3636
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.19041.3636
WDM Streaming Capture Devices:
{17CCA71B-ECD7-11D0-B908-00A0C9223196},0x00200000,1,1,ksproxy.ax,10.00.19041.4355
HD Web Camera,0x00200000,1,1,ksproxy.ax,10.00.19041.4355
HoverCam Solo8+,0x00200000,1,2,ksproxy.ax,10.00.19041.4355
HoverCam Solo8+ (Audio),0x00200000,1,1,ksproxy.ax,10.00.19041.4355
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.19041.4355
Intel(R) Display Audio Output 3,0x00200000,1,1,ksproxy.ax,10.00.19041.4355
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.19041.0001
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.19041.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.19041.0001
WDM Streaming Communication Transforms:
Audio Renderers:
EPSON PJ (Intel(R) Display Audio),0x00200000,1,0,quartz.dll,10.00.19041.3636
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.19041.3636
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.19041.3636
DirectSound: EPSON PJ (Intel(R) Display Audio),0x00200000,1,0,quartz.dll,10.00.19041.3636
DirectSound: Speakers / Headphones (Realtek Audio),0x00200000,1,0,quartz.dll,10.00.19041.3636
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
mfcore.dll, 10.00.19041.5007
mfreadwrite.dll, 10.00.19041.4957
mfcaptureengine.dll, 10.00.19041.4355
mfsensorgroup.dll, 10.00.19041.4355
windows.media.dll, 10.00.19041.4355
frameserver.dll, 10.00.19041.4355
frameserverclient.dll, 10.00.19041.4355
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
Video Decoders:
Intel? Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 10.20.0009.0015
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpegx.dll, 32.00.0015.5612
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.19041.5007
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.19041.0001
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.19041.3636
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.19041.5007
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.19041.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.19041.3996
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.19041.3636
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.19041.3636
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.19041.3636
Video Encoders:
Intel? Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 10.20.0009.0015
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264x.dll, 32.00.0015.5612
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevcx.dll, 32.00.0015.5612
Intel? Hardware H265 Encoder MFT, {BC10864D-2B34-408F-912A-102B1B867B6C}, 0x4, 7, mfx_mft_h265ve_64.dll, 10.20.0009.0015
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.19041.3636
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.19041.3636
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.19041.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.19041.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.19041.4355
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.19041.3636
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.19041.3636
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.19041.3636
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.19041.3636
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.19041.3636
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.19041.4355
Audio Decoders:
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.19041.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.19041.3636
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.19041.4355
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.19041.5007
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.19041.5007
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.19041.3636
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.19041.3636
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.19041.4355
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.19041.4355
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.19041.0001
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.19041.5007
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.19041.5007
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.19041.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.19041.3636
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.19041.5007
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.19041.3636
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.19041.3636
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.19041.3636
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.19041.5007
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.19041.4355
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.19041.3636
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.19041.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.19041.4355
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.19041.3636
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.19041.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.19041.3636
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.19041.0001
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.19041.0001
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.19041.0001
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.19041.4957
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.19041.5007
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableEncoders = 1
EnableDecoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
, , [, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
, , [, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
No Data
+++ WER1 +++:
No Data
+++ WER2 +++:
No Data
+++ WER3 +++:
No Data
+++ WER4 +++:
No Data
+++ WER5 +++:
No Data
+++ WER6 +++:
No Data
+++ WER7 +++:
No Data
+++ WER8 +++:
No Data
+++ WER9 +++:
No Data
Message 13 of 16
anurag_naik
Hi @steve_curtland,
We have noticed some cases for machines either having dual cores or on machines where windows has boot up only on 2 cores. We have released an update with a resolution for the same, can you please try once taking the latest Fusion update
Anurag R. Naik
Message 14 of 16
steve_curtland
This did not work, even after I reset the data panel again.
Message 15 of 16
RajkumarIlanchelian
@steve_curtland Can you confirm which version of Fusion are you on now? The one that @anurag_naik is referring to is on version 2.0.20508. Please note that if you upgrade to this version you will have to update all your machines to this build too as they will defer in schema from the other version you have on your other machines right now.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 16 of 16
steve_curtland
I am not on that version. I have asked IT to update and will let you know
the outcome.
