Fusion not installing in Windows 11
Running on Windows 11 - 22H2.
Attempting to do a fresh install of Autodesk Fusion and receive the following error:
Viewing the installation log, it is reporting that it cannot find a specific file. I've disabled Windows Defender during the installation but was unable to get it work.
Below is the log:
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001FA957B8E50> #
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\WINDOWS\TEMP\7zSCDAC.tmp\resources\buildinfo.json
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240201094011
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\WINDOWS\TEMP\7zSCDAC.tmp\resources
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\WINDOWS\TEMP\7zSCDAC.tmp\certs.pem
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000001FA9579BCE0>, operation=<function multiple_operate at 0x000001FA94E885E0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='file:///C:\\WINDOWS\\TEMP\\7zSCDAC.tmp/_payload/', update_connection=None, stream='production', globalinstall=True, no_auto_launch=False, no_uninstall_registry=False, install_origin='Admin', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is True <<<<<<<<
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-04-01 16:49:25,447 - MainProcess(8908) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/
2024-04-01 16:49:26,266 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-04-01 16:49:26,380 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-04-01 16:49:26,662 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Program Files\Autodesk\webdeploy\meta\registry_track is created.
2024-04-01 16:49:26,664 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-04-01 16:49:26,664 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-04-01 16:49:26,664 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Skipping pre-checks. Found environment variable SKIP_PRECHECK OR Admin install.
2024-04-01 16:49:26,665 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-01 16:49:26,665 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f7a6f4a289729f/full.json
2024-04-01 16:49:26,688 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:26,688 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:26,688 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:26,767 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-01 16:49:26,767 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f7a6f4a289729f/full.json
2024-04-01 16:49:26,784 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:26,784 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:26,784 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:26,800 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is c79c6be7-3742-4721-b960-c8f81a954138
2024-04-01 16:49:26,816 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.18719 for app 73e72ada57b7480280f7a6f4a289729f
2024-04-01 16:49:26,816 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 7886a34aba42a6e4df57abdd1795de97364374df detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 0fba9483ecaabd2f40b7f40e13ed19e05fbdf046 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1e484b55a8f9921f1b299d18e590cd7f2cfdba92 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5c7fa680458a5ac72b059788239110275d34fcf0 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk da44a78f54fec34ed4e7fdc4d2e25df6999764ec detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk dad2b2567e643c384d6e88edc9533b716625000a detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 80046041ba124b08a40d8edb55b113c4653447e3 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e84cc9403df05c383dd0447cead59ba84c2c27af detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 8ccc3847e3d228c73cbcde46e353df88302449d9 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 8a0f507ebb5cc55cef8af105a73e14823248ae1b detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c962ac0be676360d42559f336c5e6f35b2e79ee8 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1522c12261f13865df9b1573b0942038ba1a7081 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk ce4a118af44b5a0b760d652f9232ff7b604b3427 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 416ee6c1c8e0dc59bd879cb9c3d869a87503d819 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 69a869de7436e9e6e228a3274ff677a1c566081a detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5eb15a26d6f9148933206443ac74562b2c1e5e1e detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 17da5ebb79f32101a8a44367d7dc975e67d9f2e0 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk d1a57d11087f44520769277ea8c4f9437d86d91d detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 57a75bb1238af1a384aeffbeb8f951eb2d8d3ed1 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6fc05372ce172348fac3949fb36854cde62dcb9b detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 2353d9829f56427f8d23cc00ff53cd38d641d3f8 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 3151c94b3474d5ab5250986f0fd384b821519485 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk db1091095ed1b6a6d4dde75376260b9f8df09b82 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 9354edadfd5afadc188c695dc169b4c6d4e7821a detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 104d7bd8f707c459a75f7d0d2966ff5fac423e4a detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 14691e5674e6cf03c9bf6e06d8c61108a6ebe693 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b38d5a86bef903bd5a524b367895f0c3c6bfbedb detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f5d20840370a61a6de1a69b2dbcdd7c12862bc3b detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5ffa30372eee34a0d5e62791b0e4daf3aeeceecd detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f9f1e3dd5c44a6156f37fd965feab86ea0d5420f detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk a43ab46adde7f3220b2a66a8e69b30c7e6388f31 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 3fd5a745b2f6e709acd29609376e935f1a0333e1 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 17e55912af2afefad66f30ecd478668d00a4a4d6 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e45044ee0440e2122ed4f8da28f82c8f34cfcb1c detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 7e638b3beabf84cdeeca2b87b7934813dd653da9 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 73c592c74ab19b6ca3e301a07569f7497b02d380 detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c2dfd07d8c14ad72a960b2989500648ea21ca4dc detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c3dd37c410bc4a0213155711a9e65ddc846eb6ab detected on system skipping install.
2024-04-01 16:49:26,849 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b20e3c55ccfc9e4dac37fbee4721bd88c42b19c2 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 4924fb9ff0c1ec5fe97de7682d68bb7907309962 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 650ed6b47a09360a5ce6b043184c91513ba12f05 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 829f8a0ea3cb429b831cd7cd8ff71f4a7d05c6a1 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 728e0f9ba00cbf429a9b693778af51cd4e18ff98 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 4490dc834f2df5bfd9bde6fead2fdab46525e62b detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cd398d360d746179da04a19fe608256034f75a64 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk db3a70918724349831cd01d3f4ca1e63b01ae7b7 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 47eb308f4e5e99bd73b8431f37a1e9166a17fd08 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 707b02d459df30db8ad51c11c152f0bac7b3ca5b detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 878d67a5642dd04ed113c20f68fe164f2beb9279 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c395c96738f0cdbc46c3150dd055968b1914f98a detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 76e3b8594e9a6e9de6168665ba7638c25b24cefe detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1e964318970e75f6f28f8f4e24ed04607f88730a detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 239ecc749a79bec25e8647fc4c8749b6e3435cdc detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk a1341c70a5e347afd239cdbd014ceeb3749eeef1 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 2c00ef3300cc2cd58ec2f3aa3c4efe646da73872 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1edc6fb6835505d62c3f3819ec066142d9cdbc38 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e44e12388a98d954a16580c62a629f928ce37416 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 33551de9520374f7f3211cddb14a0b54780ef596 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 281ad230054ecde00e75d9d72469bbd8d5bb6a18 detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6559056f1b3c028a5e998c0ab70e324cec3fd57d detected on system skipping install.
2024-04-01 16:49:26,865 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk d7d33e101c86b226f5dec957d774577fee3d4fd6 detected on system skipping install.
2024-04-01 16:49:26,880 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1d09c88ca2a62c3958d1475d9df3699eb275bf8c detected on system skipping install.
2024-04-01 16:49:26,880 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-04-01 16:49:26,880 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-04-01 16:49:26,947 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version found.
2024-04-01 16:49:26,947 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2024-04-01 16:49:26,947 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 434a310ba39a5a127daba7317aca946c4aabe839
2024-04-01 16:49:26,947 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/packages/434a310ba39a5a127daba7317aca946c4aabe839.json
2024-04-01 16:49:26,980 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:26,980 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:26,980 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:26,980 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/packages/c2f7fba45e39ef9888fc2fee938315f3ce8e1473.tar.xz for package 434a310ba39a5a127daba7317aca946c4aabe839
2024-04-01 16:49:26,980 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from file:///C:\WINDOWS\TEMP\7zSCDAC.tmp/_payload/packages/c5da65df0c9d74d48d5447292f29a3029d9e196f.tar.xz for package 434a310ba39a5a127daba7317aca946c4aabe839
2024-04-01 16:49:27,013 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Start executing tasks thread
2024-04-01 16:49:27,013 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:27,013 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:27,029 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:27,029 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1
2024-04-01 16:49:27,029 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:27,029 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:27,029 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:27,045 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1
2024-04-01 16:49:27,954 - MainProcess(8908) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 434a310ba39a5a127daba7317aca946c4aabe839
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action e10f096356f7470ea58e13af02d1ba7c(UPDATE_PINNABLE_LAUNCHER)
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action e11b50c4e45d49c68aa944c2e476a76f(Unknown) was not in registry
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-04-01 16:49:28,032 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\streamingsession.json
2024-04-01 16:49:28,047 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 7df3ec3a7e8d40ada66494b9dc32dc4e(ACTIVATE_CONFIG)
2024-04-01 16:49:28,094 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Applications\Fusion\Fusion360App\ApplicationOptions.production.xml as \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Fusion 360.server.config
2024-04-01 16:49:28,094 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-01 16:49:28,141 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Applications\Fusion\Fusion360App\ApplicationOptions.us-production.xml as \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Fusion 360.us-server.config
2024-04-01 16:49:28,141 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-01 16:49:28,188 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Applications\Fusion\Fusion360App\ApplicationOptions.emea-production.xml as \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Fusion 360.emea-server.config
2024-04-01 16:49:28,188 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-01 16:49:28,235 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Applications\Fusion\Fusion360App\AdpSDKGlobal.production.config as \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\AdpSDKGlobal.config
2024-04-01 16:49:28,235 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\Applications\Fusion\Fusion360App\adpdesktopsdk.production.env as \\?\C:\Program Files\Autodesk\webdeploy\production\b6226a03d2af9e144aa8b1b7e17cf8eb0cd990f1\adpdesktopsdk.env
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 8df63efc00a94e9aa262d921a044c83a(PROCESS_TEMPLATE)
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 9a6f9239365141149849b3081dc3fd7c(WRITE_STREAMER_OPTIONS)
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '1' to option 'GlobalInstall'
2024-04-01 16:49:28,281 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Remove option 'DevBuild'
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Cannot get etag because of "'NoneType' object is not callable"
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'production' to option 'InstallStream'
2024-04-01 16:49:28,329 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1341bb4b8566410e9c7c8aef52bcb222(FILE_ASSOCIATIONS)
2024-04-01 16:49:28,376 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-04-01 16:49:28,376 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 4afd20f9b05b4349869fb10841d11444(DELIVER_ICON)
2024-04-01 16:49:28,376 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Deliver the icon of Fusion360.exe to the same folder as the Pinnable launcher.
2024-04-01 16:49:28,392 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-04-01 16:49:28,392 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico stat result: os.stat_result(st_mode=33206, st_ino=3659174697346828, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=177333, st_atime=1712011694, st_mtime=1711026421, st_ctime=1711992228)
2024-04-01 16:49:28,392 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico st_file_attributes: 32
2024-04-01 16:49:28,392 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico stat result: os.stat_result(st_mode=33206, st_ino=3659174697346829, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=40507, st_atime=1712011695, st_mtime=1711026494, st_ctime=1711992228)
2024-04-01 16:49:28,392 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico st_file_attributes: 32
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico stat result: os.stat_result(st_mode=33206, st_ino=3659174697347246, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=39964, st_atime=1712011695, st_mtime=1711026494, st_ctime=1711992228)
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico st_file_attributes: 32
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico stat result: os.stat_result(st_mode=33206, st_ino=4222124650768560, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=39624, st_atime=1712011695, st_mtime=1711026494, st_ctime=1711992228)
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico st_file_attributes: 32
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico stat result: os.stat_result(st_mode=33206, st_ino=3659174697347249, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=39217, st_atime=1712011695, st_mtime=1711026494, st_ctime=1711992228)
2024-04-01 16:49:28,408 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico st_file_attributes: 32
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico stat result: os.stat_result(st_mode=33206, st_ino=3659174697347250, st_dev=3471853480, st_nlink=1, st_uid=0, st_gid=0, st_size=38223, st_atime=1712011695, st_mtime=1711026494, st_ctime=1711992228)
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico st_file_attributes: 32
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action abd8ee230bcc49f9a56035b8eefedeed(REGISTER_UNINSTALL) was not in registry
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5ca4357a038540d58fb2092e8a9329a9(REGISTER_SAFE_MODE)
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Program Files\Autodesk\webdeploy\meta\streamer\20240201094011" is found
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Program Files\Autodesk\webdeploy\meta\streamer\20240201094011\streamer.exe"
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - WARNING :: Already installed the latest streamer, do not need to update the streamer
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Create shortcut file: C:\Program Files\Autodesk\webdeploy\meta\streamer\streamer.bat
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Skipping register safe mode. Global Install: True, Skip Register Safe Mode: False
2024-04-01 16:49:28,423 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-04-01 16:49:28,455 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-04-01 16:49:28,455 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 0b9a4c1251914f7facc25616ea0f9de3(CREATE_LAUNCH_ITEMS)
2024-04-01 16:49:28,455 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Create launch items for install
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is launchable. Creating a shortcut
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: destination: C:\Users\Public\Desktop, launchname: Autodesk Fusion
2024-04-01 16:49:28,470 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Trying to rename previous Fusion 360 shortcut if it exists for rebranding live update: from C:\Users\Public\Desktop\Autodesk Fusion 360.lnk to C:\Users\Public\Desktop\Autodesk Fusion.lnk
2024-04-01 16:49:28,486 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-04-01 16:49:28,486 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-04-01 16:49:28,486 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-04-01 16:49:28,486 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-04-01 16:49:28,486 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: destination: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk, launchname: Autodesk Fusion
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Trying to rename previous Fusion 360 shortcut if it exists for rebranding live update: from C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\Autodesk Fusion 360.lnk to C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\Autodesk Fusion.lnk
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-04-01 16:49:28,548 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Program Files\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-04-01 16:49:28,564 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-04-01 16:49:28,564 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-04-01 16:49:28,564 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-04-01 16:49:28,564 - MainProcess(8908) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Exception processing tasks for 434a310ba39a5a127daba7317aca946c4aabe839: [WinError -2147024894] The system cannot find the file specified
2024-04-01 16:49:28,629 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host autodesk.com is accessible
2024-04-01 16:49:28,629 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: *****
2024-04-01 16:49:28,629 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: *****
2024-04-01 16:49:28,827 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: *****
2024-04-01 16:49:28,827 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: *****
2024-04-01 16:49:28,827 - MainProcess(8908) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1190, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 95, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1120, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 932, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 1932, in _do_installation
File "R:\src\adsk\dls\streamer\process\process.py", line 1693, in wait_threads
File "D:\Jenkins\3P\PYTHON\3.11.1\WIN64_1\Lib\concurrent\futures\thread.py", line 58, in run
File "R:\src\adsk\dls\streamer\process\process.py", line 1813, in execute_tasks
File "R:\src\adsk\dls\streamer\process\process.py", line 415, in _executetasks
File "R:\src\adsk\dls\streamer\windows\platform.py", line 371, in create_launch_items
File "R:\src\adsk\dls\streamer\windows\platform.py", line 541, in _manipulate_shortcuts
File "R:\src\adsk\dls\streamer\manifests.py", line 807, in walk_external_references
File "R:\src\adsk\dls\streamer\windows\platform.py", line 476, in __filevisitor
File "R:\src\adsk\dls\streamer\windows\platform.py", line 197, in _rebrand_shortcut
File "R:\src\adsk\dls\streamer\windows\platform.py", line 191, in _get_destination
File "D:\Jenkins\3P\PYTHON\3.11.1\WIN64_1\Lib\re\__init__.py", line 185, in sub
File "R:\src\adsk\dls\streamer\windows\platform.py", line 188, in __map
File "R:\src\adsk\dls\streamer\windows\native.py", line 497, in GetKnownFolderPath
File "R:\src\adsk\dls\streamer\windows\native.py", line 761, in GetKnownFolderPath
File "_ctypes/callproc.c", line 1000, in GetResult
FileNotFoundError: [WinError -2147024894] The system cannot find the file specified
Any pointers would be greatly appreciated!
