Fusion Support
Fusion no longer displays center of mass in properties. how to fix?
4 REPLIES 4
ryan_thaler
224 Views, 4 Replies
Ive had this recent problem with COM. I design a body, as well as import components, in fusion and want to maintain a certain COM. The designed bodies are fine, however when i right click on the components and click properties, it now only shows the x value for COM and not y or z. Is there somewhere in settings where  i can fix this? thanks
4 REPLIES 4
jhackney1972
in reply to: ryan_thaler
I agree with you, the Properties panel does not show the Y,Z values of the Center of Mass.  I do not see a way to fix this, but in the meantime, you can show the Center of Mass and Measure from it to the Origin.  Not as convenient but you can get the value.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Phil.E
Thanks for reporting this.
The properties for components have this issue. It's reported internally in ticket FUS-126967.
The workaround is to right click on the body, rather than the component, to find the full set of COM results.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
ryan_thaler
thank you. nice work around
ryan_thaler
in reply to: Phil.E
thank you
