Announcements
Fusion Latest Version-
subhash.prajapati
subhash.prajapati
I am using the Fusion version 2.0.10806. There is latest version available right now which is 2.0.11685. I am trying to update my fusion with latest update. But under job status, it doesn't show me any latest version. I always work on the "online" status and Fusion 360 is always connected to internet.
Can someone help me? How should I get the new version of Fusion 360 under my job status.
jhackney1972
You version of Fusion 360, I believe, will not update because it is so out-of-date.  Go to this site, the download should start automatically or if it does not, there is a download link on the page.  Once downloaded, make sure your current copy of Fusion 360 is NOT running.  After making sure it is not running, run the file you downloaded.  This should update your Fusion 360 application.  If it does not, you may have to do a Clean Uninstall first, then use the download you just received.
John Hackney, Retired
subhash.prajapati
Thank you so much.. It works now.
