Announcements
Fusion keeps freezing up, and I cannot figure out why. Please Help me!!!
jcmynhardt
Observer
jcmynhardt
Observer
Observer
Hellp,
While working in fusion, while doing anything from moving an object, to pattern array it will freeze up completely and one of two things happens: 1. it never comes right and I restart the program. 2. eventually, after farndom amounts of time, it fixes itself. I'm pretty sure it's not a hardware issue. Please help me, I use fusion every day and it's becoming a huge inconvenience. Any advice would be hugely appreciated!!
TheCADWhisperer
What are your system specs, especially graphics card and driver?
Are you using a 3D Connexion device?
Can you File>Export your *.f3d  or *.f3z file that exhibits this behavior to your local drive and then Attach it here to a Reply?
jeff_strater
Most times, this is due to something in your design.  A large sketch patterns, complex geometry operations, etc.  As @TheCADWhisperer says, if you can share the model, that will likely help.  Also, some indication of what you are doing when these "lockups" happen would help.  Are you just rotating the view, editing a sketch, creating a joint, etc.
Jeff Strater
Engineering Director
