Announcements
Fusion keeps exiting each time it connects to the servers with no error dialog.
quentin
quentin
every time i let the internet be connected to my computer and the app connects for 10secs it exits without a crash dialog. if i launch it without the internet connected it stays running.
RajkumarIlanchelian
@quentin can you please launch it offline and then go to About -support and diagnostics - diagnostics log files and attach the zip file that gets created? It could give us insight into where it is disconnecting and crashing.
I assume you restarted the machine to see if that was a easy fix.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
quentin
here it is
quentin
I tried restarting and changing graphics driver. if i stay disconnected all is fine but when i connect for a bout 10sec everything works fine and then it tries to do something online because the connected icon gets a 1 like ab update is happening then it will not interact and then it closes. everything worked fine yesterday.
quentin
I fixed it by uninstalling and running disk clean. then reinstalling and now all works well:)
RajkumarIlanchelian
@quentin Glad you are able to get this working now. WE will look at the logs to see if there is any obvious things we can catch.
Autodesk Fusion
Join Fusion Insider
