Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Trying to shell by selecting this face fails.
Trying to offset this face also fails.
Solved by henleyi. Go to Solution.
Hi, Fusion is struggling to offset this face because there are some very high curvature regions on the loft surface. These will fold over making it difficult to produce a legal offset surface. The highest curvature is concentrated in this region:
Removing the problem part of the surface can help, for example one solution could be to cut out the problem area and fill it with a surface patch.
This allows shell to work up to about 0.2 After that it fails again due to more high curvature.
