fusion is lagging
pegurilucas
fusion is lagging
pegurilucas
well fuison starts to lag a lot a few week before it worcks just fine but now it freezes a lot ( video atached to help explain better) when i orbit it freezes for a second then worcks fine for 2 secs and freezes againg, then start to worck just fine
pc specs
Ryzen 3 1200 OC 3.7 ghz
16Gb ram 3200 mhz (OC)
RX580 8Gb 1450 mhz (stock)
SSD m.2 256 gb (filled to half )
pls help im gona be crazy i already try all the comon fixes so pls help
leowarren34
Hi @pegurilucas,
What are you running in the background?
I would also ask if not modelling the threads (use the image) would make any difference - threads add a lot of faces for not much gain.
Are any other programs crashing, how hot is your processor? You've said It's OC which means heat can be an issue.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
pegurilucas
remeber that this problem is even when i just open the program
pegurilucas
at full load never pass 70C
kajick
https://forums.autodesk.com/t5/fusion-360-support/facing-some-freezing-issues/td-p/9752759
This exact problem has already started here... please lets just use one place where we will try to fix this.
pegurilucas
ok thx
i will close this now and hope for the best plsy fix this is really anoying
