Announcements
Fusion is crashing when trying to insert files from computer
info9DN8E
info9DN8E
Never prompts to send error report. When i try to insert and SVG dxf or any file from my computer the windows explorer never pops up. So i click the watch icon on the top right side and fusion crashes. I also cannot insert logo into drawings same thing happens.
lance.carocci
@info9DN8E what is the last-used location that you expect Explorer to open to? Is it perchance network storage or removable media?
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
karina.harper
Autodesk Support
Autodesk Support
Hi @info9DN8E
This sounds a bit like a permissions problem to me. If you wait, does a dialog asking for permission to access the files pop up? Can you share your log files here?
Do you ever use an external drive to save? It could be it's trying to default to that drive but unable to find it since it's been removed.
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
info9DN8E
Reinstalled fusion and it fixed
HughesTooling
This sounds like the old old bug where the last Save or Open was a drive\directory that's no longer available. Clean install will fix it or there's a fix in this post.
Mark
Mark Hughes
Owner, Hughes Tooling
