Recently Fusion has started to exit immediately when I start it. The splash screen is shown briefly and then it exits. When I start a second time it works. This happens almost every time I start Fusion after I have booted the computer. This is on Windows 10.
This is how the log ends. I can send more of the log directly to the developers if needed.
2024-02-05T17:17:12.120Z [AdSSO:18048, 16312] [AdSSOServer.Ipc INFO] Server:Autodesk.SSO.DefaultServer-v2:18048:65287:000001DED62F9EF0: Disconnecting client since client closed the connection. Error: 2: End of file
2024-02-05T17:17:12.120Z [AdSSO:18048, 16312] [AdSSOServer.Ipc INFO] Server:Autodesk.SSO.DefaultServer-v2:18048:65287: Client disconnected. 0 client(s) connected currently.
2024-02-05T17:17:12.310Z [AdskIdentityManager:648, 3780] [AdSSOClient.Ipc INFO] Client:Autodesk.SSO.DefaultServer-v2:18048:0:0000022336438440: Worker thread finished
2024-02-05T17:17:12.310Z [AdskIdentityManager:648, 3780] [AdSSOClient.Ipc INFO] Client:Autodesk.SSO.DefaultServer-v2:18048: All connections disconnected
2024-02-05T17:17:12.310Z [AdskIdentityManager:648, 3780] [AdSSOClient.Ipc INFO] EventClient:Autodesk.SSO.DefaultServer-v2.Events:18048:65288:00000223364387C0: Stopping connection
2024-02-05T17:17:12.310Z [AdskIdentityManager:648, 3780] [AdSSOClient.Ipc INFO] EventClient:Autodesk.SSO.DefaultServer-v2.Events:18048:65288:00000223364387C0: Disconnecting from server at port 65288
2024-02-05T17:17:12.310Z [AdskIdentityManager:648, 3780] [AdSSOClient.Ipc INFO] EventClient:Autodesk.SSO.DefaultServer-v2.Events:18048:0:00000223364387C0: Waiting for worker thread to finish
2024-02-05T17:17:12.310Z [AdskIdentityManager:648, 16140] [AdSSOClient.Ipc INFO] EventClient:Autodesk.SSO.DefaultServer-v2.Events:18048:0:00000223364387C0: Failed to read from socket at port 0. Error: system:10004: read: A blocking operation was interrupted by a call to WSACancelBlockingCall
2024-02-05T17:17:12.310Z [AdskIdentityManager:648, 16140] [AdSSOClient.Ipc INFO] EventClient:Autodesk.SSO.DefaultServer-v2.Events:18048:0:00000223364387C0: Failed to read response from socket at port 65288
2024-02-05T17:17:12.310Z [AdskIdentityManager:648, 16140] [AdSSOClient.Ipc INFO] EventClient:Autodesk.SSO.DefaultServer-v2.Events:18048:0:00000223364387C0: Finished polling server for events
2024-02-05T17:17:12.310Z [AdskIdentityManager:648, 3780] [AdSSOClient.Ipc INFO] EventClient:Autodesk.SSO.DefaultServer-v2.Events:18048:0:00000223364387C0: Worker thread finished
2024-02-05T17:17:12.311Z [AdskIdentityManager:648, 3780] [AdSSOClient INFO] Uninitialized SSO client
2024-02-05T17:17:22.340Z [AdSSO:18048, 8148] [AdSSOServer.Ipc INFO] EventServer:Autodesk.SSO.DefaultServer-v2.Events:18048:65288:000001DED62F7250: Disconnecting client since client closed the connection. Error: 10053: An established connection was aborted by the software in your host machine
2024-02-05T17:17:22.340Z [AdSSO:18048, 8148] [AdSSOServer.Ipc INFO] EventServer:Autodesk.SSO.DefaultServer-v2.Events:18048:65288: Client disconnected. 0 client(s) connected currently.
