Announcements
Fusion has trouble uploading files from solidworks
ingenieriacabra
ingenieriacabra
Every once in a while (every week or so) Fusion cannot load anything. It selects the file and does the upload but when I go looking for the part is nowhere to be found. This is starting to get old and makes me lose a lot of time trying to get to work. I already had a fusion team member try to fix this but the problem is intermittent (it fixes itself sometimes the next day). Does anybody have an issue with this or what fixes have you found. I feel I should be getting some kind of refund because the software doesn't work when I try to use it since I only use it for CAM and not design...
TheCADWhisperer
@ingenieriacabra
What version of SOLIDWORKS?
I don’t think Fusion supports SOLIDWORKS 2024 version yet.
ingenieriacabra
I use an older version 2020. Maybe its too old and not supported...?
TheCADWhisperer
@ingenieriacabra
Should work fine with 2020 version.
Can you Attach an example file here?
ingenieriacabra
Don't know what to tell you but I just tried to upload a file and it worked. As I said in my original post it seems to not work sometimes.
