Announcements
Fusion hangs instantly from body "Save as Mesh"
leonknook
Message 1 of 22
leonknook
Fusion hangs instantly when I'm in the browser and right-click on a body and click on "Save as Mesh".
No error nothing. The system tries to respond but never comes back to normal operation. Clean removal and reinstallation of Fusion do not solve the problem.
My workaround for this moment is to use FILE>EXPORT. But you need only the object that you want to export visible. Very annoying way to work.
Replies (21)
Message 2 of 22
dsouzasujay
Hi @leonknook,
can you please share the Diagnostic log files
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 3 of 22
leonknook
Thank you for trying to help me with this issue.
In the attachment the files you asked for.
kind regards,
Leon.
Message 4 of 22
jeff_strater
can you share your design here?  If the model is large or complex, generating the triangles for a mesh can take a long time, it is possible that Fusion will eventually complete the operation.
Jeff Strater
Engineering Director
Message 5 of 22
leonknook
I did a windows update 10 twice, everything is updated.
I restarted the PC
I opened Fusion
I made a simple cube
I click on body > save as mesh
Fusion hangs!
I'm sorry the problem has nothing to do with a complex design.
kind regards,
Leon.
Message 6 of 22
dsouzasujay
@leonknook
Can you try again 'Save as Mesh' by running Fusion 360 Application with "Run As Admin"?
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 7 of 22
leonknook
I have executed the file FusionLauncher.exe as an administrator, but unfortunately, nothing changed, fusion hangs instantly.
Message 8 of 22
dsouzasujay
@leonknook
Try below options, if it wont work then capture a screencast video and attach it to the next reply
  • Clear the Location/Select a new location, where you are trying to Save the mesh
  • Uninstall 'Chitubox', if you have installed it on your computer
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 9 of 22
leonknook
I dont hev chutibox installed.
Look at my screencast.
Message 10 of 22
leonknook
My screencast cannot be seen here?  I made one and insert it in de reply but then notting to see after posting.
Message 11 of 22
leonknook
Message 12 of 22
dsouzasujay
@leonknook
Screencast Link: https://autode.sk/33Fz8jI
I will check with the team and get back to you, as i'm not able to figure out the problem.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 13 of 22
markus.fruehauf
A special thing about Save as Mesh is that it is looking for installed 3D Print utilities in the registry when it starts. It is checking for MakerBot, RepetierHost, Cura and Netfabb. Do you have one of them installed?
Message 14 of 22
HughesTooling
This looks somewhat like a very old bug in Fusion where it hangs if the last directory you save to is no longer available. Do you get a similar hang with Insert Mesh?
Take a look at this post for a fix.
https://forums.autodesk.com/t5/fusion-360-support/no-file-dialogs-visible/m-p/9077470#M68567
Mark
Mark Hughes
Owner, Hughes Tooling
Message 15 of 22
leonknook
I have found NMachineSpecificOptions.xml but there is a latest directory in there that still exists end is valid.
So this is not the problem.
I have deleted the line but fusion still hangs.
Message 16 of 22
HughesTooling
@leonknook  Watched your video again and I see you're not even getting as far as the dialog below so yes does look like a different problem!
When you say in your first post that you did a clean uninstall, did you use the clean uninstall tool?
Mark
Mark Hughes
Message 17 of 22
leonknook
I have removed Cura, Netfab, and Repetier Host.
Restarted the PC
Then I use the clean install tool for Fusion.
After that  I did a new install of fusion, the problem still exists, Fusion Hangs (from body to save as mesh).
this is a really serious problem
Message 18 of 22
leonknook
Fresh start Fusion.
I go to "Utilities"
Then I click on "Make"
Then I click on "3D print" Fusion Hangs!
Seems like there is a problem.
I have no Cura, no Repetier no Net fabb installed.
Message 19 of 22
markus.fruehauf
Did Save As Mesh/3D Print work for you in the past or did it never work?
Message 20 of 22
leonknook
Yes, it worked without any problems in the past.
From a body save to mesh.
I wonder if there aren't references somewhere in a file to 3D printer slicers that I could delete.
The windows error logs shows that Fusion comes in an endless loop.
