Announcements
Fusion freezing up to a minute when doing ANYTHING
luisc.zarate
luisc.zarate
It starts fine but literally I click any buttun, select something, change Fusion tabs, new sketch, etc. It freezzes up to 1+ minutes.
Sometimes is works perfect and a lot of the times I have this issue. I have reistalled it several times, cleared the cache and don't know what else to do.
Video file attached
Specs:
i7
nvidia 1070
16gb ram
more than 200bg storage
Phil.E
Looking at your video, I can't help but notice the job status icon (small clock at the top) has an indicator there is an update available.  I'm wondering if you are seeing this during the time that the update is actively downloading.
Can you try restarting Fusion, and if a 1 appears on the clock again (perhaps you are still in need of an update), does the behavior return?
If you restart Fusion and no new build begins to download, so there is no 1 on the job status icon, does the problem continue?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
