Announcements
Fusion freezes, saturates efficiency cores only on M2, then resumes
rprovideo
rprovideo
Hi
I was finally able to do a meaningful recording about this. I had this really annoying on a big model I work on, where sometimes more complex actions like save, undo, or selecting a bigger chunk of the model can freeze Fusion for 5-10 minutes.
I had this on my Macbook M1 and it was so annyoing I bought an M2, which is lighting fast. Mind you, sometimes this does not happen at all, the other day I had a big assemlby model, which is over 200MB and is usually painfully slow, work for an hour without any problems. When I opened it the next day (after some component changes) it was again back to one action every 10 minutes.
Today I was working on a relatively simple model, (which I can share privately) and was able to capture signs of the problem. I was doing actions in the drawing space that I see tripping the model up, like changing wireframe and paper size.
You can see that some actions take a long time, and give me the old wristwatch icon. None of them increase CPU or GPU pressure, though.  However, when I change the sheet size, the machine gives me a beachball. Then suddenly all the powerful Performance cores shut down, and the Efficiency cores saturate fully. The Activity monitor indicates the software is not responding. After a while, though, it exits whatever loop it was, and does the job.
Sometimes I saw the wristwatch icon to come up for a minute, then suddenly all the efficiency cores go up, but only for a second, and bam, the job is finished.
for some reason it wont let me insert a screencast, but here is the link: https://autode.sk/3BZqDPo
also I saw when the screencast was compressed, a similar thing, except only the performance cores went up, the activity monitor would say screencast uses a lot of CPU, but it was not red, and it was done in 3 seconds.
it seems to me somehow Fusion wants to use the low-end cores, and kills them, not using the machine in its fully potential, while the other autodesk product does.
rprovideo
here is a screenshot of it making a second projection. This time it uses all the cores briefly, and finished the operation. Mind you, then I did it again, and then it only used 1 of the performance cores, and did it so bad I had to force quit. It did these spikes and then stopped the CPU but never gave back the cursor for about 10 minutes.
rprovideo
anybody?
ClintBrown3D
Hi @rprovideo
Are you running Fusion using Rosetta? Or is it just natively installed on your mac?
Clint Brown
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
rprovideo
unfortnately, Autodesk has not ported Fusion to native apple architecture yet, so the only option is to run thru rosetta. Which I have to say, 80% of the times is really fast. This must be some sort of cpu allocation bug, but I am not knowledgeable enough to say.
