Announcements
Fusion fails to launch on Mac
rwpinto763BC
rwpinto763BC
I have used Fusion for a decade. For the first time, Fusion is not launching on my Mac. None of the icons are indicating that a launch is underway. During my last use, there was an indication that a the application file was damaged. The Autodesk Service Utility does not launch either. The Remove Autodesk Fusion 360 app does launch, but I did not use it. Should I try reinstallation? What is the best procedure?
RajkumarIlanchelian
@rwpinto763BC To me this sounds like this could be a shortcut issue where shortcut may be having an issue.
1. Try to delete the shortcut and then go into launchpad and launch Fusion from there. If that does not help then please do uninstall, re-download the installer and then re-install.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
rwpinto763BC
Launching from Launchpad fixed the problem! I could not originally launch directly from the Finder. Just a single launch from Launchpad fixed the Finder issue. I then of course just replaced the Dock shortcut. Thannk you for your help
