Fusion does not launch I'm posting diagos logs for case 19892114
tmulone
tmulone
Hoping this will help get me back using Fusion 360
dsouzasujay
Hi @tmulone
Could you please launch Service Utility Tool and Repair Fusion 360?
If not can you try below steps?
  • Right click on the Autodesk Fusion 360 icon on your desktop and click properties
  • Under the compatibility tab, click 'Run this program in compatibility mode for:' Select 'Windows 8' in the dropdown
  • Click on settings 'Disable fullscreen optimizations' and 'Run this program as an administrator'
  • Click Apply
  • Goto your task bar and hover the cursor over the fusion 360 icon until the preview window pops up and then hover the cursor over the preview window and right click, select maximize. You may need to do this a second time after you login to your Autodesk profile.
Let me know if it works.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
tmulone
That seems to work. Is this something I'm going to have to do whenever I'm going to use the program?
dsouzasujay
@tmulone
Im trying to understand which one worked?
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
j.ducker
I was having a very similar issue to this where I could not launch Fusion. I would get the splash screen then nothing after that except a blank white window that was minimized in the task bar and which i was unable to switch to. I had tried everything suggested elsewhere for this issue - repairing, reinstalling, updating drivers etc... but simply right clicking on the preview window and manually maximizing it as you suggested got it to finally work again. I still have to do this every time on launch but at least it's usable.
