Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion did not start, no error message
1 REPLY 1
andi.cr
254 Views, 1 Reply
Hello everyone,
My fusion is not starting anymore, following steps i did several times:
1. de-install fusion and clean with the tool (fusion cleaner) the disk after that re-install -->no start
2. de-install and clean manual --> no start
3. run "sfc /scannow" no errors
4. de-install antivirus and firewall --> no start
5. set in the router firewall that PC temporarily to Exposded host --> no start
6. use different user accounts (also a new user) --> no start
7. start with admin rights --> no start
8. i check the account in a vmware (oder windows10 pro) --> Account is ok, here it start, but less performance
Here the log "autodesk.webdeploy.streamer.log"
2020-03-02 10:04:47,434 - MainProcess(1120) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2020-03-02 10:04:47,434 - MainProcess(1120) - MainThread - adsk.dls.streamer - INFO :: #        #
2020-03-02 10:04:47,434 - MainProcess(1120) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002458CCABA20> #
2020-03-02 10:04:47,434 - MainProcess(1120) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2020-03-02 10:04:47,434 - MainProcess(1120) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\info\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2020-03-02 10:04:47,434 - MainProcess(1120) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\info\AppData\Local\Autodesk\webdeploy\meta\streamer\20191031110444\resources\buildinfo.json
2020-03-02 10:04:47,449 - MainProcess(1120) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'reconfigure', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'write_through', 'writelines']
2020-03-02 10:04:47,449 - MainProcess(1120) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2020-03-02 10:04:47,449 - MainProcess(1120) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20191031110444
2020-03-02 10:04:47,449 - MainProcess(1120) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: de_DE
2020-03-02 10:04:47,465 - MainProcess(1120) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\info\AppData\Local\Autodesk\webdeploy\meta\streamer\20191031110444\resources
2020-03-02 10:04:47,465 - MainProcess(1120) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2020-03-02 10:04:47,465 - MainProcess(1120) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2020-03-02 10:04:47,465 - MainProcess(1120) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2020-03-02 10:04:47,465 - MainProcess(1120) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=True, connection=None, force_full=False, fulluninstall=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x000002458CE1E730>, pipes=None, procfac=<function uninstall_process at 0x000002458CDC58C8>, profile=False, pull_dest=None, purge=False, quietmode=True, stream='production', threadscount=5)
2020-03-02 10:04:47,465 - MainProcess(1120) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2020-03-02 10:04:47,465 - MainProcess(1120) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2020-03-02 10:04:47,465 - MainProcess(1120) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2020-03-02 10:04:47,465 - MainProcess(1120) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2020-03-02 10:04:47,465 - MainProcess(1120) - MessageThread - adsk.dls.streamer.ui.headless - INFO :: Begin sending message in headless mode.
2020-03-02 10:04:47,503 - MainProcess(1120) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2020-03-02 10:04:47,503 - MainProcess(1120) - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2020-03-02 10:04:47,565 - MainProcess(1120) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2020-03-02 10:04:47,587 - MainProcess(1120) - MainThread - adsk.dls.streamer.process - INFO :: Primary app is 73e72ada57b7480280f7a6f4a289729f
2020-03-02 10:04:47,603 - MainProcess(1120) - MainThread - adsk.dls.streamer.process - INFO :: The session id is da76e802-ae6c-49b8-8ff0-aee573636d9a
2020-03-02 10:04:47,603 - MainProcess(1120) - MainThread - adsk.dls.streamer.process - INFO :: Configure app begin Cleanup
2020-03-02 10:04:47,603 - MainProcess(1120) - MainThread - adsk.dls.streamer.process - INFO :: Cleaning up old-version apps, ignoring any apps except for packages belonging to an in-progress app
2020-03-02 10:04:47,634 - MainProcess(1120) - MainThread - adsk.dls.streamer.process - INFO :: Check app: 73e72ada57b7480280f7a6f4a289729f
2020-03-02 10:04:47,665 - MainProcess(1120) - MainThread - adsk.dls.streamer.process - INFO :: Configure app complete Cleanup
2020-03-02 10:04:47,665 - MainProcess(1120) - MainThread - adsk.dls.streamer.process - INFO :: Process Complete in 0.16275048 seconds
2020-03-02 10:04:48,104 - MainProcess(1120) - MainThread - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2020-03-02 10:04:48,104 - MainProcess(1120) - MainThread - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2020-03-02 10:04:48,104 - MainProcess(1120) - MainThread - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2020-03-02 10:04:48,104 - MainProcess(1120) - MainThread - adsk.dls.streamer.configuration - INFO :: #        #
2020-03-02 10:04:48,104 - MainProcess(1120) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002458CCABA20> #
2020-03-02 10:04:48,104 - MainProcess(1120) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
it look always like this:
Big thanks for any help
1 REPLY 1
andi.cr
in reply to: andi.cr
I hope the solution is not the re-install of the os.
