Fusion crashing on component selection
vinicius.strini
Message 1 of 8
vinicius.strini
Hi, I'm having trouble with a design. This design consists of two components. When I open the design and move the mouse cursor over the first component, it should display its shadow in 3D. However, Fusion stops responding, and I have to close the software. It's quite frustrating to work with because this component is part of an assembly, and every time I need to move it, Fusion crashes. I discovered the latest version of the design where this issue doesn't occur, and the difference with the next version, where the problem arises, is the modification of the height of a referenced sketch on the origin plane.
I marked the component and the sketch that are causing the issue. On the right, I also highlighted some features that, if deleted, will also cause the problem.
Replies (7)
Message 2 of 8
jhackney1972
You will need to attach your model.  Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Message 3 of 8
vinicius.strini
I'm sorry, you will find the model attached to this message.
Message 4 of 8
jhackney1972
I see no issue with your model except for a few timeline problems, mainly with missing profiles.  I can mover it around, edit it in various features without issue.  You may want to lighten the model up by Removing the sub-assembly the model came from by right clicking on it in the Browser and choose Remove from the context menu. The model after this operation is attached.
Message 5 of 8
jeff_strater
Thanks for the model, @vinicius.strini - I found that the first time I selected "Component1", it was, indeed a bit slow.  But, it did not crash.  Selection took about 30 seconds.  Then, after that, I was able to select that component very quickly.  We will investigate this, but Fusion is not crashing.
One tip:  Turn off "Show default measure".  This tries to compute a lot of stuff about the selection, and can be slow:
Jeff Strater
Engineering Director
Message 6 of 8
vinicius.strini
I'm starting to believe that it's my computer. Is there any configuration that I could change? None of the suggested solutions worked. Here is an image showing the state it gets into:
It's not a definite crash, but I left it in this state where the CPU usage stays at 100% for about 1 hour, and the program doesn't respond. My hardware specifications are as follows:
Processor: Intel I7-10750H
RAM: 32GB dual channel 3200MHz
GPU: NVidia RTX 2070 Q-Max Design 8GB
OBS: I noticed that if I make changes to the design without selecting the component directly first, the issue doesn't occur. For example, if I make changes to another sub-assembly first and then select the component, the problem doesn't happen.
Message 7 of 8
jeff_strater
interesting...  When I tried it again, I let it run for 10 mins or so, and it did not ever finish.  I have no idea what I did differently the last time, because it definitely was slow the first time, but then was fast on subsequent selections.
I also noticed that a Compute All after open seems to prevent the problem - another workaround to use.
I created bug FUS-130059 for this issue.
Jeff Strater
Message 8 of 8
vinicius.strini
Thank you guys for the solutions provided and for opening the bug report!
I found a version of the design that doesn't have the issue and worked on it until reaching the final design, and the problem stopped occurring. The difference is that I didn't remove any features like I did in the version that started causing the problem. I will close the topic.
Best regards
Vinicius Strini
