Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion crashes and hangs tool library opens on second screen
1 REPLY 1
qcampbellQP57L
70 Views, 1 Reply
Fusion will hang and crash when the manufacture tool library opens on the second screen of a 2 monitor desktop setup. Only happens on the non primary screen as set by windows.
The tool library will open fine on the primary screen, over the the active fusion app screen. Also works fine when dragged to a second screen, but if the tool library is closed on the second screen and an action to reopen the tool library is taken, the library will open on the second screen, freezing and crashing fusion. Additionally, after reopening fusion (after the crash) and reopening the tool library it will open on the second screen, freezing and crashing again.
The only solution to fixing this is to unplug a monitor, open fusion, and force the tool library to open on the only available window.
Tags (2)
Labels (1)
1 REPLY 1
Phil.E
in reply to: qcampbellQP57L
Thanks for the report and detailed workaround instructions. I logged a ticket for developers. In the mean time, please try to avoid it using the steps you outlined. (CAM-53498)
Phil Eichmiller
Software Engineer
Quality Assurance
Technology Administrators
