Announcements
Fusion crashed and my arrows changed?!
simone04marini
simone04marini
I made Fusion 360 crash (too many poligons but it was predictable) and after restarting the arrows changed style. has anyone ever seen this happen? Can I revert back to normal?
jhackney1972
What function are you executing when these arrows are displayed?
John Hackney, Retired
simone04marini
I was simply moving a solid, the same arrows appear also for all other actions that display arrows normally (like Extruding, Push/Pull face or Chamfer)
jeff_strater
I'm not sure what you mean by "changed style".  This is what the manipulators in the Move Body command look like for me:
which look the same as the image you posted.   This is the normal display.  What did they look like before?
Jeff Strater
Engineering Director
simone04marini
This is odd, I looked for a tutorial, and the arrows there have a more rounded style, the same that I had (and seen in many other tutorials).
the same style appears/appeared for any kind of action.
jeff_strater
ah, OK, I suppose that is possible, if you were running a fairly old version of Fusion.  I can't remember when the manipulator graphics were changed, but I think it was quite a while ago.  A crash would cause an already-downloaded update of Fusion to be invoked, and if the display had changed, you would notice it then.  I wonder what version you were running previously.  Anyway, what you have now is the way those arrows are supposed to look, and there are no options to change them
Jeff Strater
