Fusion cam error- Failed to open output file Error 19
6stringsplus2WSJR
6stringsplus2WSJR
This started last night. Every Gcode file I try to post process generates this the following error-
Error: Failed to open output file 'G:\Filename\SR37 Bass\Neck\FB Down\ggg.nc' (system error 19).
Code page changed to '1252  (ANSI - Latin I)'
Start time: Monday, June 6, 2022 5:31:43 PM
Code page changed to '20127 (US-ASCII)'
All toolpaths on all renderings are doing the same, plz help I have work to do.
All my toolpaths on all my renderings are doing this plz help I have work to do.
seth.madore
What post processor are you using, and can you completely describe your workflow?
Is this a custom post processor?
If so, please share the post AND a Fusion file that is giving you issues.
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
6stringsplus2WSJR
Post processor- Carbide3d(GRBL)
It doesn't matter which toolpath I try to post or which file, it generates the same error.
