Fusion API DXF import problem
ScottFergTMXEZ
Message 1 of 8
ScottFergTMXEZ
A recent update to Fusion 360 broke my FMGears (C++) add-in. It worked in Fusion version 2.0.19440 x86_64 but fails after upgrading to 2.0.20948 x86_64, so somewhere in between a change occurred to break FMGears. It uses DXF import to generate a sketch with the profile of the gear, i.e. importManager->createDXF2DImportOptions and importManager->importToTarget.
This import process now imports the gear's profiles as construction curves rather than normal curves as it did before. This causes an error when trying to extrude elements of the sketch to create the 3D gear. I may have a workaround for the issue, but this seems like an undesirable breaking change for ALL users of this API function and should likely be corrected.
Replies (7)
Message 2 of 8
HughesTooling
This bug has been reported and acknowledged by Autodesk. It affects DXF import in general, not just the API.
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
ScottFergTMXEZ
Where can I find this bug report so that I may track it and know when an upcoming update with the fix will be released?
Thanks!
Message 4 of 8
Steven_Gao
It's just an internal defect tracking system. Usually, we listed the fixed issues in What's new of each major releases and also posted it in forum like below:
https://forums.autodesk.com/t5/fusion-design-validate-document/november-2024-update-and-community-bu...
Message 5 of 8
ScottFergTMXEZ
Is there any update to the status of this bug? 4 weeks now and still no resolution?!
Message 6 of 8
HughesTooling
@ScottFergTMXEZ InsertDXF seems to work correctly now so is this now just a problem using the ADI to import DXF files?
Mark Hughes
Message 7 of 8
HughesTooling
@ScottFergTMXEZ With the update that caused the problem there was also a change to allow import\export of construction lines. Experimenting a bit using Rhino3d and looking at DXFs from Fusion, what I've found is anything on layer 1 will import into Fusion as construction geometry. Does the add in you're using import the gear on layer 1 by any chance?
Mark Hughes
Message 8 of 8
ScottFergTMXEZ
Yes, that's extremely helpful and provides a useful workaround for my problem!!
This still seems like a very serious break to DXF import. Layer "1", I suspect, is a very common name used by many legacy producers of DXF files, now broken by this change. Do they plan to correct this, or just document it as a new "feature"?
FYI: FMGears is actually an add-in I created and made available now for many years for free. So I can change the code to avoid layer "1", work around this breakage, and make this functionality once again available to my users.
Thanks so very much, Mark!
