Fusion 360 wont install on Windows 11
imechura
Message 1 of 8
imechura
Im trying to install a newer version of fusion 360 on my computer because on the version that I have the buindled post processor for my machine wasnt tested or something because it gives javascript syntax errors when I attempt to post. So after spending a few hours trying to fighure that out, I decided to upgrade fusion so I downloaded the installer and ran it. It runs for a few minutes and fails with a message saying "we don't know what went wrong".  I did it 3 times and it failed each time..... The error message told me to come to this site for help. So I typed up this very message and went to post it and it crashed the darn chrome browser so I had to do it again. Seriously? Every single interaction that I have had with autodesk software today has involved an error or crash and consumed even more of my time. I was under the impression that autodesk software was supposed to lead to an increase in productivity, maybe I misunderstood because I'm a day late on my project.
Here is what I found in the log. I'm probably going to have to figure out another way to do this job because I am already running very late from screwing around trying to make software work all day.
Replies (7)
Message 2 of 8
RajkumarIlanchelian
@imechura The logs shows this error/article - https://help.autodesk.com/view/RSTR/2023/ENU/?caas=caas/sfdcarticles/sfdcarticles/Installing-Fusion-...
Can you check you do a speed test or is it possible to see if you connect to another network (a hotspot maybe) and see if that improves the experience? If that is not possible can you try restarting your router ?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 8
imechura
At the time of falure my internet speed is 17 MBPS download and 17 MBPS upload. There is nothing wrong with my internet connection. Everything else is working except the fusion 360 installer.
So if yall wont provide an offline installtion and your installer wont work, then is there a way to disable the annoying messages on my current version of 360 that keep telling me to upgrade?
Message 4 of 8
imechura
Or even more helpful would be to provide a postprocessor for GRBL that does not throw an error due to missing variables when its run.
Message 5 of 8
RajkumarIlanchelian
@imechura @As you are launching Fusion 360 press Ctrl+Shift to bring up the Fusion 360 service utility. In here if you do a repair does that help?
Autodesk Fusion
Join Fusion Insider
Message 6 of 8
imechura
Actually, no posts seems to work in fusion. Ive tried 5 random post processors and all of the m failed.
Message 7 of 8
imechura
Ive given up on the install. If I can't get this to post then I am abandoning this software.
Message 8 of 8
RajkumarIlanchelian
@imechura @Did the repair not work?
Autodesk Fusion
Join Fusion Insider
