Announcements
Fusion 360 won't load in Windows 11
markG9VAK
Observer Observer
markG9VAK
Observer
Observer
Have searched for a answer.... nothing is working. I have a new computer and Fusion 360 installed fine.  When I try to launch it, it comes on as normal, loads the build screen then immediately goes away.  Nothing in the task manager.... just goes away.  Not really sure what to do.  New computer is very fast.... but, something is messed up.
Thanks for any insight,
Mark
Michiel.Valcke
Hi, this is the AutoCAD forum, not a lot of people here will be able to help you with Fusion 360.
Hopefully the people over at the Fusion360 forum can better help you.
shannon5K9H8
Not sure what Michiel.Valcke is talking about. This is a Fusion 360 support forum. I do think that opening a support ticket would be a good way to go however. My money is on a graphics driver problem.
Michiel.Valcke
@shannon5K9H8 clearly the post got moved to the right forum after I posted the above ^^
jswickJ9PWC
I had the same issue when I upgraded to Win11. I had to uninstall, then reinstall Fusion and it has worked since then. I did not delete any extra files; I just used the typical Windows "uninstall program" function to remove it. After reinstall I had to change a few configurations but everything else was saved and ready to go. Hope this helps.
martinlmarriott
I have the same issue on a brand new (two weeks) high spec Win11 PC.
Fusion loads the splash screen and starts to build the GUI but then will disappear itself. If I run the “Fusion 360 Client Downloader.exe” it will run again. I don’t have to uninstall first.
I have to do this almost every morning which is getting tiresome but it is random as sometimes it works fine.
