Fusion 360 will only run once before requiring a clean install to run again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I am trying really hard to use Fusion 360 and when it works it's great. The problem I am having is that it will not run after the first time.
I install it and it runs fine after the install process but if I close it or reboot my PC it will not run unless I perform a clean install again.
It does show up in task manager as running but does not open any UI.
I have a high Spec PC built for video editing. It is on Windows 10 Creators Update.
I have tried disabling AV and Firewall.
I have added rules to my firewalls as per the guide.
I don't use a proxy.
I have only ever run it as Admin.
I have been through the forums and looked at a number of suggestions but still not found a solution.
Any input would be greatly appreciated!
Edit: Now it has failed to install and can't be uninstalled or repaired. Disaster of a weekend trying to learn to use this software!
