Announcements
Fusion 360 will not update.
dbuch
dbuch
I have restarted my PC and it still fails to update. I printed out the diagnostic log. Where do I send it? I was trying to open a file from one of the other members and it wouldn't let me do it and said the file was created by a newer version of Fusion360.
David
RajkumarIlanchelian
@dbuch Can you please do the following? (BTW you can attach the log files right here in the post).
1. Go to Fusion - help - support and diagnostics
2. Select Fusion service utility
3. Choose the repair Fusion option
This should help you get on the new version.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
dbuch
Fusion 360 update failed.jpgThe Drag and drop here does not work. Perhaps it is because I am using FireFox and not Chrome.
Here is the link to the diagnostic log.
https://drive.google.com/file/d/1I3j94yXeox91hGyE1DXjBoCS_ud_N-1B/view?usp=sharing
RajkumarIlanchelian
@dbuch Will take a look at the logs but please try the repair that I called out above.
Autodesk Fusion
Join Fusion Insider
dbuch
Thanks!
