Announcements
Fusion 360 will not start
richowen42
richowen42
Please could someone offer some ideas.
I am using a Microsoft Surface Pro 7 with a i7 1065G7 processor and 16GB RAM.
the system is a corporate device but has no antivirus or firewall. My user is an administrator
Fusion takes ages to get past the splash screen then loads a larger white screen and eventually stops on
“This site cannot be reached
accounts.autodesk.com took too long to respond
try:
checking the connection
checking the proxy and the firewall
ERR_TIMED_OUT”
As i said there is no antivirus or firewall other than windows default. I have tried disabling windows firewall/ defender etc. I have added rules in the firewall, changed DNS, confirmed route to the internet has no proxy etc.
i have also gone through the forum and cleared cache folders, reinstalled fusion as administrator tried running as administrator.
its driving me insane, everything else runs great.
please could someone help?
thanks in advance
dsouzasujay
Hi @richowen42,
Can you please attach the installation log files in the next reply.
Windows:
C:\Users\***\Appdata\Local\Autodesk\autodesk.webdeploy.streamer.log
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
richowen42
Thanks for responding. Ive attached the log.
dsouzasujay
Hi @richowen42 ,
The installation log files are not showing any errors.
Can you please delete all the installation log files in the below location
  • "C:\Users\***\Appdata\Local\Autodesk\autodesk.webdeploy.streamer.log"
Then Uninstall fusion 360 using Automation Uninstall Tool.
Install fusion 360 again.
If you are seeing the same error please send me the latest installation log file in the next reply.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
richowen42
Hi i have done that before posting.
But i have just gone through the process again and have the same issue.
Please note i dont have a proxy and i dont have DNS issues, i tried setting it to google and open DNS same issue.
I also disabled windows firewall and all its other protection as a test but i still have the same issue
My other laptop is using the same WiFi and works fine.
Any other ideas?
richowen42
Finally got this working it seems it was a DNS problem on my machine. i followed most of the steps in this video:
https://www.youtube.com/watch?v=10D1IJQ2qV0
but in short what fixed it was:
Reset browser settings.
Set IP settings to Automictically detect.
In control panel - internet options - connections - LAN confirmed "auto detect settings" was ticked and "use proxy" was not.
In services.msc checked DHCPclient was running and set to automatically start
In command prompt as administrator type the following:
Ipconfig /release
Ipconfig /renew
Ipconfig /flushdns
Netsh winsock reset
Netsh int ip reset resetlog.txt
Netsh winsock reset catalog
Netsh int ipv4 reset reset.log
Netsh int ip reset
Restart machine.
Everything internet related has improved speed and response wise.
Thanks for offering assistance though, hopefully this helps someone else too.
dsouzasujay
@richowen42 ,
Good to hear.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
