Announcements
Fusion 360 will not start
dario
Message 1 of 8
dario
Hi everyone
Fusion 360 will not start after installation and it previously ran on my system. There is no error code it just wont start.
In the Task Manager i see Fusion Launcher.
I tried reinstalling it but it did not work.
I tried reinstalling it in safe mode it did not work
I use the Fusion 360 cleander and deleted all the temp files it did not work
I disable my Anit-Virus Programm it did not work.
All my Video Card drivers and Windows is up to date.
My PC Specs are:
i7 6700k
Nvidia Msi 2080 super
1 Gbit Internet Connection
Replies (7)
Message 2 of 8
plasticjoe
Community Visitor
Community Visitor
I am having the same issue also
Message 3 of 8
davewolfe
Agreed. It says it can't see the server for me. I've tried logging into the Fusion hub on the website and that doesn't work either.
Dave Wolfe
Isaiah 57:15
Want to optimize Plant 3D? Check out the Plant Roadmap Workshop
Tips and Tricks on our blog: ASTI blog
Plant 3D Wish list
Message 4 of 8
dario
Hi @davewolfe
What exactly do you mean with Fusion hub ?
I think we have a different problem. I can logon to https://myhub.autodesk360.com and see all my Projects.
Also do you have a Error code ?
Maybe you can open another thread with more Information so People can help you more specific.
best regards
Dario Bauer
Message 5 of 8
If it helps im having the same issue. Install and then nothing.. wont even error or try to start. But it does show in task manager.
Message 6 of 8
Here I have a link to the dump file that I created from the process that is in task manager.
Hopefully this can help find a solution.
https://1drv.ms/u/s!Atn3h_SEeWm9g-B_1YfEOgFdy-SKWQ?e=hBXw9G
Message 7 of 8
I have the solution!!!
BLOODY windows feature update!!
have a look and see if you also need to do a feature update. it might say Up-todate but have a look underneath and see if a feature update needs to be carried out.
Hope this is also your problem.
let me know if you need a hand.
Message 8 of 8
dario
Worked for me aswell do all Windows Updates and now it works again!!!!!!!!!!
Thank you very much.
best regards
Dario Bauer
