Announcements
Fusion 360 will not show color on components or bodies
dylan.edmiston03
dylan.edmiston03
I have been using Fusion 360 for a long time now and have recently run into an issue that I believe occurred during the last automatic update.  All of my bodies and components have no color. As you can see attached, they are colored when in the menu but not when they are opened.  I am running Mac OS Mojave.  I deleted Fusion 360 from my computer and redownloaded Fusion 360 from the Apple Store.  The problem persisted after I did this.  Please help, it is hard to work on Fusion 360 without this dimension.
Thank you,
karina.harper
Autodesk Support
Autodesk Support
Hi @dylan.edmiston03
You need to click the little display at the bottom of the screen where you can select visual style. From there you can change the display style of your model.
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
dylan.edmiston03
Perfect, I didn't know that.  Thank you!
I am also facing the same issue and tried out the solution provided but still it did not help. The default colours of the bodies and components are not present when you open the file. All the components and bodies are grey in colour when you open the file.
g-andresen
1. check this setting
2. show a screenshot
günther
