Announcements
Fusion 360 went extremely slow after the May 2022 update
firebloodphoenixHRBBH
After the update yesterday, Fusion installed onto my and my college's computer went very slow, it freezes when trying to edit a tool path. and unfreezes after a second, The problem seems to be on the CAM side. It was working fine then I saw an update and restarted fusion to apply it. My college has the same issue after applying the update. Please advice.
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @firebloodphoenixHRBBH, thanks for posting.
I think that there could be a few things that you can check:
  • Clear local user cache according to this article
  • Try some different graphics settings described here.
  • If you are working with large models or assemblies it may be worth checking this article.
  • Pay attention to the Fusion 360 System Requirements. They are frequently updated with new releases.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
KJB5150
Same here.  Even just editing a tool in the tool library is painfully slow.  Click or type anything, count to 3, and maybe - MAYBE after the 3 seconds, Fusion has acknowledged that you entered in input.  --  I notice that if I open up my task manager Fusion has between 7 to 12 "C++ Framework" and other programs running and is using between 2GB to 4GB of RAM..
izaktokarski
I'm having this same issue, tried everything including a clean install. Have any luck figuring out what might be causing this?
