Announcements
Fusion 360 update warning
AndreySeleznev
Message 1 of 21
AndreySeleznev
After installation on new PC Fusion 360 display following warning when I try to open a model created on the old PC:
"The saved version of the file uses data that can only be viewed with the latest version of Fusion 360. Update Fusion in order to view this data."
My new PC runs the latest Fusion 360 version.
Replies (20)
Message 21 of 21
RajkumarIlanchelian
@AndreySeleznev Thank you for the new invite. I see 4 design files in there and I was able to successfully open all the 4 of them without any error or warning messages.
Can you please go into the Service utility again and try to do a "Repair Fusion " and see if that helps? It certainly seems to be some cache kind of issue on the machine that is causing this problem. I am continuing to look at the logs as well.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
