@jeffmaxwellsd,
Thank you for sharing your log file. I've found few error messages
WARNING :: Read operation error: [WinError 10054] An existing connection was forcibly closed by the remote host... recovering
WARNING :: Exception in Update This process failed because of another installer cross process live update in process
WARNING :: Failed to extract to \\ \***\USER\AppData\Local\Autodesk\webdeploy\production\0c6c8be812b2dce050a3457de4077e03313640ae\FusionDocStream\Autodesk\FusionDocAcad\AcLineType.dll: Process Aborted
**Edit***
It seems that there is a streamer delegate communication error and there should have an exception handling in our program so that they will be investigating it.
To resolve this issue, please close (kill) all fusion related processes, such as “FusionLauncher.exe”, “Fusion360.exe” and “streamer.exe”. then should reinstall and then reinstall again.
This is a clean uninstallation program and Link to download Fusion
Sorry for the inconvenience caused.
Fusion 360 is a cloud based system so all of your modes are uploaded on A360 site. you are able to check whether your models are in https://myhub.autodesk360.com/
You can see your model on your machine as well. so you can make a backup file. (but we can only see the files saved within 60 days)
Window :
C:\Users\[User name]\AppData\Local\Autodesk\Autodesk Fusion 360\[My account number]\W.login\
Mac :
HD\User\[User Name]\Library\Application Support\Autodesk\Autodesk Fusion 360\[My account folder]\W.login\
Many thanks,
Ahreum.
