I am used to Inventor where hitting ALT+Enter within the tool library brings up the edit option for the selected tool. This past Sunday I performed that key stroke within Fusion's library and now my scaling is weird. After hitting the keystroke, my screen went black for a second, a very low resolution displayed for another second, and then it went back to 4K resolution, but with the odd scaling. Check out the attached picture. The tool library and the data panel are scaled to 100%. Windows is currently set to 175% because of my 4K monitor. Even the icons within Fusion and their associated text aren't correct. I can hit ALT+Enter again within the tool library and the same black screen, low resolution and funky scaling happens. I'm using Windows 10 with the latest Nvidia Quadro drivers.
I've tried the following:
Setting a custom scaling in Windows
Ensured under the Fusion launcher that "high DPI scaling override" is disabled
Ran the Fusion Clear and reinstalled Fusion
Tried the manifest strategy found here:
https://forums.autodesk.com/t5/fusion-360-design-validate/uhd-display-issue/td-p/6040129/page/2
I spent 1.5 hours on the phone yesterday with Autodesk Support but we came up short with a solution. I just realized today that ALT+Enter is what did this. Does anyone else know what's going on or how to fix it?
