fusion 360 STP files not showing part numbers only body, plate, or tube
dgall6DZYF
dgall6DZYF
At my shop we use several types of CAD programs I use Fusion 360 when a customer sends a stp file the other cad programs in the shop show part numbers of the details while Fusion 360 only show either Body, Plate or tube how do I make it show the detail numbers? I have attached two pictures of the same file on one on Cadia and one on Fusion 360. It makes it very difficult to make a bill of material (BOM) without part numbers
Phil.E
Fusion will keep the names and browser structure for step files upon translation. Check the step/stp export options on the "other program". It is apparently flattening the assembly into a body folder rather than keeping the assembly hierarchy.
If you could share the design it might help solve the mystery.
Phil Eichmiller
Software Engineer
Quality Assurance
dgall6DZYF
Hi Phil is there a way to sent just you the file this is for a customer I do not want to make it public
Phil.E
I sent you an email. Thanks!
Phil Eichmiller
Software Engineer
Quality Assurance
dgall6DZYF
Thanks Phil I am just going to post one of the more basic stp files and a snippet  when the guys open it with Enovia or Cadia it gives a part numbers with fusion it comes as a plate, tube ect I need to figure a way for it to show it as the part numbers. I need to know if it can be done and if so if I have to open it a certain way or if the customer has to save it different. Thanks Dave
dgall6DZYF
Phil.E
This is only a guess, please take it as such. Based on the step file I think this is the issue.
https://catiav5v6tutorials.com/how-to/saveexport-assembly-in-igs-step-stl-format-in-catia-v5/
This describes an export workflow that seems to address this issue. Please test it out.
Phil Eichmiller
Software Engineer
Quality Assurance
