Fusion 360, STL file, open & insert mesh, convert to solid model
downy06
Observer Observer
downy06
Observer
Observer
If you use open when creating a mesh as a solid model, you need to make a t spline to b rep through convert from the form again after the convert mesh.
However, using insert mesh, a solid model is created with a single convert mesh.
I wonder why there is a difference between the number of converts and the method of generation.
hamid.sh.
Can you elaborate on this, perhaps by a screencast or screenshot?
The only two differences I know is that:
1. When opening an uploaded mesh design history is initially off and this gives some extra commands in the toolbar, (including the whole Form workspace), contrary to using Insert Mesh in a existing file where design history is on (if you haven't turned it off already).
2. Insert Mesh gives you a few extra options (unit and positioning parameters).
Hamid
