Fusion 360 Splash Screen Stays At Software
firatfarisdede
firatfarisdede
Hello there,
When we want to open the Fusion 360 program, the opening screen comes up and this screen and the text remain constant even if the program is opened. I can open files but it doesn't appear on the main screen and the startup screen just stays. I share the photos in the attachment too:
I changed it to DirectX 9 or 11 in the settings but nothing changed, I also did the video card updates, but nothing changed, unfortunately.
ryan.bales
Autodesk Support
Autodesk Support
It's still likely graphics dependent but might be more tuning on the graphics side. Can you upload a screenshot of graphics diagnostics in Fusion?
Ryan Bales
Fusion 360 Product Support
firatfarisdede
Sure:
[GPU Information]
GPU Device: Intel(R) HD Graphics 4000
GPU RAM: 32 MB (Integrated card)
GPU Driver API: DirectX 9.0
GPU Driver Version: 10.18.10.5161
GPU Driver Date: 08/31/2020
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Notebook has an onboard shared display card.  And we were using fusion nearly for 6 months without problem.
ryan.bales
Autodesk Support
Autodesk Support
Can you try switching it to DX11? IF that does not work, try the solution found here:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Mod...
Ryan Bales
