Fusion Support
Fusion 360 simulation help
1 REPLY 1
riot92
66 Views, 1 Reply
Hello everyone! I need help with Fusion 360 simulation. I have two different pipe clamps and would like to simulate the different pressure on the pipe for each clamp. What simulation should I use? Below are example pictures. Thanks.
1 REPLY 1
henderh
in reply to: riot92
Hi @riot92,
A linear static stress simulation should be sufficient, assuming there will be small deformations.
We offer a tutorial that can be used as a guide: Tutorial: Static stress analysis
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
