Announcements
Fusion 360 quit unexpectedly
dangartland
dangartland
I have the error "Fusion 360 quit unexpectedly".
Fusion quit error.pngWhen I try and load Fusion it shows the splash screen for a split second then always gives me this error.
This happened after I received the "The last time you opened Fusion 360 it unexpectedly quit while reopening windows" crashing loop.
I was working on a drawing when Fusion froze, became unresponsive and never became operational. I had to quit Fusion and this started the crashing loop error. I am running on MacOS High Sierra, Version 10.13.5.
I found this support page which states that I should have to completely uninstall and reinstall Fusion 360.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Una...
Surely there is something else I could do to solve this, since this is the third time I have had this error this week.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @dangartland,
Thanks for posting. We are investigating this issue but are having a hard time reproducing. Would you have some time today for a screenshare session to go over this issue together? If so, please email me at james.youmatz@autodesk.com
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
keqingsong
Hey @dangartland, we just pushed a small update last night that should have addressed this issue you're seeing. Can you try again and let us know that you're able to get back into Fusion 360?
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
ma78348
Observer
Observer
Hello, a few days ago this happened and I am still unable to open fusion. When I tried to open it, it will bounce on my dock for a few second and quit on its self, apparently, this also happened with my design teacher on her computer, do you know how I could fix this? I already tried to reinstall and have used the fusion 360 cleaner as Autodesk suggested bit it doesn't work. I also tried to restart my computer and I get the same result every time.
zeblis
I 'm having the same issue, and wanted to share my Error Report(at the bottom).  I have completed the instructions here:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
and the uninstall instructions here:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I've just re-installed from the current version.  Still get this "quit unexpectedly" error.  Thank you for your help!
