Fusion 360 online - open file from my computer.
I'm using the online version and the "open" button only allows opening a file from the project, not from my computer. How do I import a local file into the online version?
The "open" button suggests it can be used to open a local file...
...However when I click it, I just get the ability to open online files.
davebYYPCU
Your button for local files should be here.
They will need the operating system and Licence you are running.
@Phil.E is this a Personal Licence limitation?
HughesTooling
If you're using the browser version of Fusion, you'll need to upload the file using your online hub. Then in Fusion's data panel right click the file and select Create Fusion Design.
Mark Hughes
Owner, Hughes Tooling
jeff_strater
not really familiar with the online version, but I think all local file operations are blocked in that version, as it is primarily targeted at Chromebook users.  There should be a way, however, to upload a design to your project.
Jeff Strater
Engineering Director
