Fusion Support
Fusion 360 on IPad
4 REPLIES 4
Mustang69
779 Views, 4 Replies
Fusion 360 on IPad
I use Fusion 360 alot to share with my customer for viewing mostly
Today I used the Fusion app on my newer IPad and there is issue
If I am not touching the screen the product is not showed. Looks like this
but as soon as I touch the screen the product shows as it should
is there a problem with the app or something else?
4 REPLIES 4
jhackney1972
in reply to: Mustang69
You need to reset your iPad.  Hold the power button until you see the Power Off slider, or something similar, and slide it to shut your iPad down.  Wait about a minute then hold the power button until you see the screen light up.  Once it is up and running, Fusion 360 app should work correctly.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Mustang69
in reply to: jhackney1972
Aahhh it worked!👌
Love this app for showing our customers!
lbudziene
Are you able to model on the iPad or just view?
g-andresen
in reply to: lbudziene
view only!
günther
