Announcements
Fusion 360 not taking the capasity it should
joni.bippus
Observer
joni.bippus
Observer
Observer
Hello i have a big problem with Fusion,
i tryed to Install it on my home pc and it just doesnt wanne start fast. If i wait 30 min it will start but i dont want to waste that mutch time. My pc infos are down below, if i start Fusion it wont take any CPU or GPU capacity and very less RAM according to the Task Manager, i tried Reinstalling and launching as admin and it still didnt work.
My pc:
AMD Ryzen 7 5800X 8-Core
32 GB DDR5 Ram
NVIDIA GeForce RTX 3080
and its installed on a KINGSTON SKC2500M81000G (SSD)
Replies (7)
RajkumarIlanchelian
@joni.bippus Can you please share your log files with us?
1. Close Fusion 360
2. Launch Fusion 360
3. Once it launches Go to About->Support & Diagnostics -> Diagnostics logs
If you can attach this here it will help us understand why it takes 30 mins for your Fusion to start.
If you disconnect internet from your machine and then start Fusion, how long does it take to start Fusion. Also, what is your internet speed if I may ask?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
joni.bippus
Observer
Observer
Hello again,
i tried to start it and now it didnt even let me touch enything post login, without internet it started faster but didnt let me in cause i need to agree the terms or smth. My internet according to a speedtest gots 104 Mbps Down- and 34 Mbps Upload and a ping of 18 ms.
RajkumarIlanchelian
@joni.bippus
Can you pease refer to this article on how to launch Service utility on windows
1. https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Ove...
2. launch the utility
3. gather system info
4. Attach the zip files here
5. Then run the repair Fusion 360
Now does Fusion function better?
Autodesk Fusion
Join Fusion Insider
joni.bippus
Observer
Observer
Sooo i tried repairing and it still doesnt work at all. I hope the Diagnostics are not on german :D......
RajkumarIlanchelian
@joni.bippus Thank you for the logs. We will take a look at it.
To summarize:
1. Previously you were able to launch Fusion but it took 30 mins to launch
2. Now you can ;launch it faster? (or still takes 30 mins) but after launch, you can login? but you cannot access Fusion after you login, right?
3. Does it just freeze or does it give you an error message?
Autodesk Fusion
Join Fusion Insider
joni.bippus
Observer
Observer
When i tried Lauching it with Internet on it still took a long time and then after login it freezed up and crashed. Without Internet i can lauch it faster but it wont let me in, cause my account didnt accept the terms.
i Tried it again now and still the same results
RajkumarIlanchelian
@joni.bippus
1. Do you have any other Autodesk products on your machine? If so can you log in there and then launch Fusion 360?
2. Can you follow this article and install the AdSSO called out here? https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/simplecontent/content/autodesk-s...
Does any of this help?
Autodesk Fusion
Join Fusion Insider
