Fusion Support
fusion 360 not supported any more
3 REPLIES 3
waynefixall
157 Views, 3 Replies
the installation does not continue as the version of 360 is not supported any more.
so how do  i get 360 installed
3 REPLIES 3
@waynefixall @Did restarting the machine to get rid of the multiple installs help?
also please collect the logs from this error and attach here.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
No
@waynefixall
1. Restart your machine
2. Make sure task manager does not have any Fusion exe running
3. go to add/remove program
4. Select Fusion 360 and select modify
5. this will launch fusion service utility
6. Run repair fusion 360
does this help?
Autodesk Fusion
Join Fusion Insider
