I've used Fusion 360 for over a year now with minimal issues until today. When I was viewing a .dxf file, fusion crashed and would not start up again, so I went through fusion's troubleshooter and chose to do a clean reinstall. I downloaded Fusion's clean uninstall tool and the tool removes Fusion 360. However, when it does this it says fusion 360 was removed with some errors. After that, I deleted the autodesk folder in the %appdata% folder then reinstalled Fusion 360. After when I try to launch Fusion, I still have the same issue. I have updated my computer to the latest version of windows 10, restarted my computer multiple times, and run the program as administrator and theres no change. Whenever I try to Launch fusion 360, all I see is this black screen-
Any help on this issue would be appreciated, I have some time sensitive work I need to get to. I also have attached the log files.
