Fusion Support
Fusion 360 not launching
4 REPLIES 4
jeet.kanaskar
137 Views, 4 Replies
Ive been trying to get into my fusion 360 and it just wont open . Anyone else getting the same issue? theres no issue witth my pc and ive restarted , reinstalled multiple times.
4 REPLIES 4
this is the screen im seeing for context
@jeet.kanaskar Can you give us the logs please?
1. Go to add/remove program
2. Select Fusion - Modify
This will launch the service utility
3. Run the "Gather system info"
4. This will generate two zip files
Will need the Fusiondiagnosticslogs.zip
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
@jeet.kanaskar Couple of other things to try:
1. Are you connected to multiple monitors? If so can you disconnect them and try?
2. If you switch to a different network (say your mobile hotspot) is the launch successful then?
Autodesk Fusion
Join Fusion Insider
yes i am , i am on an ethernet but im now in , thank you , i reinstalled graphics driver and restarted it opened .
