Fusion 360 not displaying upper and lower task bars
After not using Fusion 360 for a while and updating it today, it would show a black taskbar. While I am still able to click on the various icons, I cannot see them, which has made it a nightmare to work with.Screenshot (3).png
HughesTooling
There are several posts below about this, this one for example with a fix.
Mark
Mark Hughes
Owner, Hughes Tooling
dsouzasujay
Hi @Anonymous ,
Could you please try adding the environment variables.
If above solution is not working.
Restart your PC and try to launch fusion 360
If you still see the same issue, then
Please Remove/edit below Environment Variables
  • Variable Name: QT_OPENGL
  • Variable Value: software
And add below Environment Variables.
  • Variable Value: angle
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
